V. F. Alphanumeric Display Controller — Parallax Forums
Dan990Dan990 Posts: 13
edited 2010-03-14 06:44 in BASIC Stamp
i have a MIC10937 V. F. Alphanumeric Display Controller and i want to use a Basic Stamp 2 to control it. i have no clue how to use the SEROUT. so if anyone can give me a sample code for this chip i would appriciate it.
    edited 2010-03-13 17:43
    Examples of SEROUT abound in PBASIC Help.
  • Dan990Dan990 Posts: 13
    edited 2010-03-14 03:53
    i know that but i have no clue what baud rate to use. and the chip has a serial clock in. i have no clue where it would go. and also i have no clue on the data to send to it.
    edited 2010-03-14 04:12
    So, it looks like you need to find the datasheet for your display controller. Since it uses synchronous data you will need to use shiftin and shiftout.
    - Stephen
    Post Edited (Franklin) : 3/14/2010 4:21:26 AM GMT
    edited 2010-03-14 06:35
    www.cate.com.au/download/Z8/databooks/mic10937.pdf
    Here is the data sheet. if someone could make a code that i could just modify a value for different words. it would be greatly appreciated
    ok i just took a look at the SHIFTOUT command. from what i understand from it and the data sheet: SHIFTOUT 0, 1, MSBFIRST, [noparse][[/noparse]00000001]
    should display the letter A.
    correct me if i am wrong
