NEW: Screw Terminal Board for Propeller Platform
Nick McClick
The idea of the TermBoard is to give you a more sturdy connection than a breadboard, but still give you flexibility to change wiring. It uses 16 sets of Molex® Terminal Blocks to connect P0..P27, Vin, V50, V33 and Ground and has a standard shortboard footprint with matching mounting holes. Here it is on top of the upcoming Propeller Platform SD;
project page
Of course, it also fits just fine on the Through-Hole Propeller Platform. It's also nice when connecting un-tinned braided wires - here it is connected to WBA's TH1M Temp-Humidity sensor and a power supply I picked up at Halted:
Anyway - more info on the project page. I also put up a few more photos on flickr.
As usual, the design is available under the MIT license. Design files are available for download on the project page. Let me know if you have any questions!
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
project page
I see that you supply a DIY electrocution kit with every model ...
Get the casing back on that Mains PSU before there's a nasty accident!
T o n y
Sadly, my power supply death-trap came without a case, so I don't use it. But I'm sure 120VAC @15A would really 'light up my life'.
Leon Heller
Amateur radio callsign: G1HSM
We do use 220 @ 60Hz in the US for big house-hold appliances and 110 for everything else ....
Nick, you've been on a roll lately. Must be nice having a partnership on those boards with Jon and "free-press" advertising.
Short answers? Not available at this time since I think you deserve more information than you requested.
A lot of modules were published by designers on the site - James Long, mctrivia, rayman, Tim S., and so on. I've done a few designs, too.
Industrial companies in north america usually use 3 phase 600v or 347v single phase.
120v single phase in homes. The 240v is achieved by using a second phase that is 180 deg out. Or 208v by using a phase that is 120 deg out.
I missed this board design. Look good though spring connectors would have been nicer
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
The dangerous bit of that PSU is the DC Volts across the cap
Style and grace : Nil point
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
EDIT: Not sure if it was already there, but I found the .dip file on the project page. I have diptrace installed, but the file doesn't open and an error message pops up saying "Format is incorrect!" Do you have it in a different file format (preferably eagle) that you can upload?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
(no longer new) SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Post Edited (Vaati) : 3/15/2010 9:48:43 PM GMT
Nope, I don't have an eagle version of the file. You just need to download the latest version of diptrace to read the file.
