Getting timing right on the SX
Let's say that I want the ability to do any kind of square wave, either ½, ¾, ¼ duty cycle, of any frequency I want. It could be for doing a RS232 kind of protocol, or PWM for motor control or whatever.
Could someone on the forum please explain this a bit? What are the equations I should use?
The way I understand it right now... You take the Oscillator frequency, say 4_000_000 oscillator cycles/second. Then, since the SX runs at 4 oscillator cycles/ machine cycles, you end up with 1_000_000 machine_cycles/second.
Then, let's say you want a square wave beep at 4_000 audio_cycles/second, so you then must divide the 1_000_000 machine_cycles/second by the 4_000 audio_cycles/second to get 250 machine_cycles/audio_cycle.
Assuming a duty cycle of 20%, I must then multiply the 250 by .2 to get 50 for my on_time, and then to get my off time, multiply 250 by .8, and get 200.
So, would the pseudo-code look something like this?
Please tell me if I'm on the right track with this. This is a major part of understanding the SX, is it not?
Formula in text:
A=(((Freq Osc)/(Machine_Cycles/Freq_Osc))/(Audio_freq))*(duty_cycle)
Start
Load 50 into register A
Load 200 into register B
turn on pin
On_Loop
decsz register A
goto On_Loop
turn off pin
Off_Loop
decsz register B
goto Off_Loop
goto Start
Formula in text:
Having said that, let's look at your question. The most important piece of information you left out is what are the highest and lowest frequencies you want (need) to generate? Without knowing that super critical bit of information, it's impossible to give you the best answer. It's like saying you want to make a car. Fine, but without knowing the speed range, you could be building a Formula 1 race car or a Honda Civic.
So, what is your frequency range?
PeterM
This question came up, because I'm trying to explain the SX to my 13 y.o. son. The freqs for the game would be in the audio range, for the beeps and bloops, so I'd say about 100 Hz up to 3000 Hz. Your thought on "engineering to meet your specifications" is right on. On a separate project I'm working on, it's easy to keep coming up with new features. The hard part is implementing them. Like Thomas Edison said, invention is 1% inspiration, and 99% perspiration. (That's a separate project btw, a remote controlled Lego car using SX as the steering module). This timing problem applies to it too, because I'll use PWM for driving the geared steering motor, which is mechanically coupled to an encoder pulled out of a ball style mouse. Anyway, 100 Hz up to 3000 Hz with little concern for accuracy.
