Interesting Problem.....
jknightandkarr
www.newarkknights.net/myprog%20orig.zip
www.newarkknights.net/myprog%20mod.zip
First off here's my program, the original, functioning normally, the 2nd is slightly different to allow me to change the freq of my tones, which isn't working like it should
P0-11 connected to PPDB's blue leds, 0-11
P12-19 connected to 8 red leds in breadboard
P20 & 21 connected to PPDB's pushbuttons. Buttons 4 & 8 to be exact
P27 connected to a Piezo Speaker then to Ground,
The original program, functions as it should. The red leds scan back & forth, blue all light up in sequence with a tone before each led lights up. The modified program, the Blue leds function as written. I only adjusted those leds btw. The Red led's scan at an increadably slow pace, like one change every 60 seconds or something. This program was already done as desired & I didn't touch it. So why is it going real slow over the changes in the program for the blue leds w/tones when they are run in different cogs??? I reprogramed the original program back in & starts to work normal again, but once the new program is once again written, the red leds don't work as expected. I've tried looking the programs over & notice no problems that should cause it. I had this same problem when writing the original program, once i added the blue leds in cog 2 for the first time, but after some adjustment worked, but this time I don't get it. What is the issue here? Makes no sence to me.
Joe
I'm going insaine. It's SOOOOOO much fun. lol
Joe
I know you've got a floor and ceiling on the divide value. It would be possible for one divide value to be zero if one of the WAITCNTs fetches the divide value between the time that the "divide--" is done and the "divide #>= 1" is done. That can happen, but only occasionally.
Post Edited (Mike Green) : 3/11/2010 6:05:00 AM GMT
Joe
Post Edited (jknightandkarr) : 3/11/2010 7:13:55 AM GMT
Joe
the lower limit for a waitcnt in spin is 385
any value lower will result in waiting for 55 seconds until the counter matches the missed value again
so before executing the waitcnt you have to code something like this
Delay := Var1 / divider if Delay < 385 Delay := 385 waitcnt(Delay + cnt)best regards
Stefan
Ok. I'll try that. The code i'm using is from the Propeller Education Kit Labs book. Ch 4 I/O & Timing Basics, pg 60. What I don't get is my original program works just fine, but after some mods with another method, an error in anothert shows up.
Joe
2) When you have a program that works until mods are added, look to the mods and what they do in order to figure out why. It may be timing. If you're using more than one processor (cog), the mods may shift the timing of execution in one cog relative to the other. Maybe there's a problem with a shared value. Who knows?
I had a request for a video of the problem working, so here it it. Meanwhile I'm going to continue to try & figure out the issue.
Joe
elseif ina[noparse][[/noparse]21]==0 divide-- divide#>=1are causing the trouble. Remember, you started another COG which uses divide to calculate a waitcnt-value BUUUUT ... divide-- can set divide to 0. If timing is changed between your input-loop and the scanner it can happen that the scanner picks the value just in that moment and before divide#>=1 can set it back to a meaningfull value.
2 solutions:
1. Use locks to access the variable - would just make a good training
2. Use another local variable and do the -- / #>1 with this variable. Then you copy the end-result into divide
PS: another solution:
3. let the min-value of divide be 2, then the worst that can happen is that the scanner picks a 1 before the value get's corrected to 2
Yes ... this was indeed an interesting problem, as the modification did not do much, it only changed the timing to make the error visible.
PPS:
· cognew (Scanner, @stack0)
· divide:=5
You should also move divide:=5 before cognew, because scanner is using divide. This is not really a problem, as cognew needs much longer to load the spin interpreter, but who knows what changes come next. If you put some code in between cognew and divide:=5 this might become a problem.
Post Edited (MagIO2) : 3/12/2010 7:31:56 AM GMT
Joe
Can this line be explained alittle more, specifically what would Var1 represent? The clkfreq? I've tried EVERYthing everyone has suggested, (not including the locks one, I'm not sure what they are), including modifying my Pub surveilance to send only the desired freq to tones.spin & my duration & pin be included in there instead, as well as moving things around in the Pub start & Pub scanner areas, so far NOTHING fixes my issue, the only thing that does is something like going from "waitcnt(clkfreq/divide+cnt)" to something like "waitcnt(clkfreq/10+cnt)".
Joe
Post Edited (jknightandkarr) : 3/13/2010 2:45:27 AM GMT
Delay := (Var1 / divider) #> 385
and
Delay := Var1 / divider if Delay < 385 Delay := 385 waitcnt(Delay + cnt)code lines for future referance. Thank you to all who tried to help me solve this one!!
Joe
opening the pdf-manual and do a search for a keyword is always a worth a try
so searching for "#>" leads you to page 43 telling
#> --or-- #>= Limit minimum (signed); p 155.
Limit Minimum ‘#>’, ‘#>=’
The Limit Minimum operator compares two values and returns the highest value. Limit
Minimum can be used in both variable and constant expressions. Example:
X := Y - 5 #> 100
The above example subtracts 5 from Y and limits the result to a minimum value to 100. If Y is
120 then 120 – 5 = 115; it is greater than 100 so X is set to 115. If Y is 102 then 102 – 5 = 97;
it is less than 100 so X is set to 100 instead.
As you aksed to explain Var1 more.
It will be MUCH EASIER for you to understand what var1 stands for if YOU post YOUR code containing the waitcnt-commands
Than I can adapt my explanation to YOUR code
If you tried almost everything and nothing worked it is REALLY time to attache your code to a posting.
ANY other way is guessing around in the fog moving forwards as slow as a dying turtle
best regards
Stefan
Joe
I wasn't looking too close at the first posting
ClkFreq is a constant.
If the result of clkfreq/divide is smaller than 385 the command waitcnt waits for ca. 53 seconds until te counter matches the value again
example with easy to follow values
let's say cnt has value 1000 if the SPIN-interpreter STARTS executing the waitcnt-command
if you do waitcnt(1010) this value is too small
until the SPIN-interpreter REALLY executes the waitcnt-command the systemcounter is already at 1385
so the value 1010 was run over and then the counter will count-up to 2^32 wrap around to zero and count up to 1010
and this takes 53 seconds
the waintcnt-command STOPs the cog COMPLETELY until the free running systemcounter matches the value (here 1010) exactly
there is no comparing like is equal or bigger. the compariing is only is EXACT equal
best regards
Stefan
Joe
