Help with Display — Parallax Forums
Help with Display
logan996logan996 Posts: 281
edited 2010-03-13 01:35 in BASIC Stamp
this is a $6 display on elec-goldmine.com i was wondering if it would work with the BS2? and if it would what would i need? Need an answer ASAP! thanks!!!·· http://www.goldmine-elec-products.com/prodinfo.asp?number=G17320
    edited 2010-03-11 00:18
    The datasheet looks like it's a standard parallel LCD (www.optrex.co.jp/us/product/newpro/RoHS/pdf/DMC16205NY-LY-BGN_Eng.pdf). It might behave like Parallax's 16x2 parallel LCD. Look at the existing sample code and schematics for the Parallax display.
  • rixterrixter Posts: 95
    The only thing I saw different than many is that they don't specify one of the pins for Anode for the LED backlight. It looks like they tap into VCC for that and expect you would control switching of the backlight via the Cathode.
    Rick
