Why do I need a motor controller?
Hi all,
Ok, this may be a basic question, but I’m not totally sure why I need a motor controller on a geared DC motor. i.e:
Let’s say I have a 18 volt DC motor that’s designed to run at 22 amps max. Why not just connect the 18-volt battery, with switch, to the motor. Turn on the switch, start motor, turn off, etc. I understand that if I needed to reduce speed, or needed any sort of variable speed control, that a controller is necessary. But if it’s as simple as on/off, do I still need one? Also, if I wanted it to run slower couldn’t I just hook up a potentiometer or a smaller battery?
Thanks for the help.
John
John
Check out the Propeller Wiki·and contribute if you can.
If by switch you mean a relay which you trigger with a microcontroller I/O pin that will work if you take care to ensure you don't exceed the current requirements of the microcontroller. It is also possible to use relays in such a manner to increase the voltage to a motor and control its speed. Erco has a thread where he did exactly that.
I have a personal preference for a transistor h bridge and pulse width modulation (PWM) for speed control. But directly controlling them with a microcontroller has two problems. The first is you will consume four or six I/O pins (depending upon the h bridge) to control two motors. The second is you need to keep signalling the motor just to get it to run at a constant speed. Now here's where a motor controller helps. It usually handles all these details for you and you signal it using serial I/O and two pins.
Expedia.ca
