Making P30 high resets Propeller Demo board if USB is not connected ???
Bean
On my demo board, if I make pin 30 high it resets the propeller chip.
I have a program that transmits data to the PC, but I need to run it without a PC too.
Is there any way to prevent this rebooting ?
To see the problem, load the attached program into the EEPROM.
When you turn on the demo board when it is connected to a PC all the LEDs will stay on.
If you are NOT connected to the PC they will flash as the propeller keeps getting reset.
Bean.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Post Edited (Bean) : 3/10/2010 3:55:58 PM GMT
PUB Main dira[noparse][[/noparse]23..16] := 255 outa[noparse][[/noparse]23..16] := 255 dira[noparse][[/noparse]30] := 1 outa[noparse][[/noparse]30]:=1 repeat
Bean.
Thanks for bringing this up!
I saw this for the first time last night with one of my programs which uses the Parallax Serial Terminal object for debugging variables. I was starting to think I was going to have to do some bug hunting soon.
OBC
Coming soon to a browser near you! PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
But I don't know ???
Bean
John Abshier
So I guess the RX pin stays low until it is connected to USB. This makes sense since a serial BREAK is the line held in the not-active state (which would be low). And a cable not connected would be considered a BREAK.
Bean.
There's a sneak path for power through the FTDI chip when there's no PC connected and that causes resets as you describe. The transmit signal from the Propeller ends up partially powering the FTDI chip and there's enough power to produce a reset pulse. Solutions include:
1) Leave a PC connected
2) Don't transmit through the FTDI chip if there's no PC there (leave pin 30 in input mode)
3) Disconnect the reset line except when you're downloading to the Propeller
4) There was one other solution involving a stiff pullup on the FTDI chip, but I don't remember the details.
·http://forums.parallax.com/showthread.php?p=847290
Jim
Duane
