Interface LED Badge with Stamp?
I have one of those 7X21 LED badges, which has a USB connection on it for interfacing with the PC.· Does anyone know if there is a way to interface one of these to a Basic Stamp, either via the USB port on the badge or an internal hack?· Thanks!
However, my first LED display used a hand wired 20x7 display with a BS2 and has code modifications for an SX if you wanted to use one instead.
http://forums.parallax.com/showthread.php?p=561144
·But I suppose you might be able to re-write the code for the Badge to get it to work with a BS2 but sounds like a challenge due to lack of interrupts.
Good to be here..!!
Mick..
badge holders
