testing spider
many months ago I said I was going to try to archive the parallax forum january 1st.
well it did not happen because other things came up. I have goten back on this project and starting now I am attempting my first test run of my spider. Will get back to you when it finishes.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
ps command tells me it is pid 19789 that i will want to kill
1) downloading of avatars fails. my test code works so the problem must be in the spiders parsing of the url.
2) parsing of post body fails.
I have attached the template i am using. anyone want to make a better one? I can define any more dynamic html tags you need. final site layout will have the following directory structure:
1 to 40 is the number of each forum.
P.S. I remembered how to kill the thread.
kill -9 19789
