Using Ground and Power Planes on 2-layer boards
I think the consensus is it's a good idea to put a ground plane on one layer of your board. But what's the best practice on the other layer?
I've seen a few boards put a power plane, and a lot of boards only put signal traces, although I haven't seen many that put a full ground plane on both sides. What do most people do?
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Copper pour on both sides of a board will help with EMC.
Leon Heller
Amateur radio callsign: G1HSM
I did hear once that putting GND on both sides can act as a waveguide in really high frequency circuits, but anything with a wavelength that short is beyond my skills anyway [noparse]:)[/noparse]
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
A waveguide is completely different. I think you mean stripline, which is a track with ground on the layers above and below it, which forms a transmission line. Microstrip, which just has a single ground on one side, is more commonly used.
Leon Heller
1 - The ground plane is the reference for DC, and a power plane is the reference for AC. Not sure exactly what that means, but it sounds good.
2 - I've read in a few places that say it's a bad idea to flow a ground plane under a crystal because it can generate noise. It makes some sense, but it probably depends on how noisy your power source is.
3 - Having a ground on one side, power on the other side creates a capacitor, although my quick calcs show it's pretty weak (something like 10pf for a 3" x 3" board on .062 FR4).
@mctrivia - I think if you flow ground on both sides, you can run into impedance issues, although I think most of your boards have tons of vias connecting both pours.
@Brad - yeah, this is probably more relevant at higher speeds, I'm mostly curious as to the best practices
Even now I still tend to call the copper pour a ground plane.
A ground plane in PCB assembly is a layer of copper that appears to most signals as an infinite ground potential. This helps reduce noise and helps ensure that all integrated circuits within a system compare different signals' voltages to the same potential.
Parallax Engineering
Some boards like the Propeller demo board run very few traces on the bottom and the entire bottom pour seems to serve as a very effective ground plane.
Tracy Allen
www.emesystems.com
Yeah, I consider the copper pour a regular trace, and think about return flow, noise, etc. I use the 'route keepout' all the time in diptrace, and you can also do island removal in diptrace. All my boards have mask, but I've done a few barebones prototypes, and soldering is a pain when you have a copper pour. My concerns are impedance matching and noise.
I never thought of doing a keepout around the pads (I've only done a mask-free proto twice), but that's a great idea. FR-4 isn't as 'hydrophobic' as mask, but it's a heck of a lot better than HASL!
I think unconnected islands are better than having nothing, although I usually remove them for aesthetic reasons.
Is it fair to say there's not usually a problem running a power pour on one side, and a ground pour on the other? Of course, it depends on a million things, but it sounds like the only specific side-effect is slight capacitance (a few pF).
Leon Heller
Leon Heller
I pour my designs in sections after all power and ground traces connect. That way I have ensured that the connections are as I required. I actually place the prop power and ground plane before anything else as this is critical for overclocking, which BTW means it is also required for normal operation. Unfortunately, it is something that has been learned from years of laying pcbs and testing in the emi labs (because they have all sorts of test equipment available including spectrum analysers).
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
