Penguin bot won't execute program unless it's plugged into serial terminal
Marz Krishna
I've been running demo code on the penguin but, and for some reason it won't run it's program unless it's connected to the serial terminal. If i turn it on and it's not connected it just does a plit(left leg goes back-down, right leg goes forward-up). How do i make it execute the loaded program when i turn on the power?
Parallax Engineering
after checking it, i get 5v from the batteries.
Post Edited (Marz Krishna) : 3/9/2010 11:23:03 PM GMT
You should always have a spare new battery set on hand for immediate use.
Load the program, turn off Penguin, remove the usb cable, switch on
Penguin, and let it go!
humanoido
*Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
*Minuscule Stamp Supercomputer *Tiny Stamp Supercomputer *Penguin with 12 Brains
*BASIC Stamp Supercomputing Book *Three Dimensional Computer *StampOne News!
*Penguin Tech *Penguin Robot Society *Toddler Humanoid Robot Project
*Ultimate List Prop Languages *Prop-a-Lot *Prop SC Computer - coming soon!
*Prop IB Hypercomputer - under development *Robotic Space Program
Post Edited (humanoido) : 3/10/2010 12:51:24 AM GMT
What program are you running? Try a different program.
Did you calibrate the servos using the servo calibration program for the program you are running?
Which calibration program did you use?
Can you test the batteries under the load of servos running?
What voltage do you see?
Which rechargeable batteries are you using?
Check to see if the servos plug into their respective left - right sockets.
humanoido
I've been running the autonomous program, but i've also tried the "penguin radio" program(same problem).
I tried both of the autonomous programs.
Yes, i calibrated it.
I use the calibration program that came with it.
Under the load of the servos i'm getting 7v. so the voltage isn't dropping, with my other set i get 6v, and the same problem.
I'm using an off brand liIon.
I checked and rechecked the sockets and tested and ran programs.
I saw in another post the guy said it took one step, i'm thinking it's the same problem. I can't just turn it on and have it run my program.
with the cable attached? (For the radio program to operate properly, you
will need to previously have the compass calibrated.)
Keep Penguin on, remove the cable, and what happens?
Then push reset, and what happens? Again, sorry, but
you will need a fresh set of batteries out of the store package to
test this.
humanoido
Post Edited (humanoido) : 3/18/2010 12:23:14 PM GMT
Can you get this to repeat exactly the same at different times?
or is it intermittent and random?
humanoido
with Penguin robot (and the provided test programs from the
download site) by the telephone with everything ready for
testing and call Parallax Tech Support so they can step you through
some tests in real time. Parallax is known for outstanding tech
support and rest assured your Penguin will soon be in perfect
condition.
humanoido
Sighs, ready to put this thing up on the shelf...
Often the joy is not so much in the having, its in the building...
Post Edited (Macore) : 3/26/2010 10:52:40 PM GMT
humanoido
humanoido
*Ultimate List Prop Languages *Prop-a-Lot *Propalot Stuff *Prop SC Computer
*Prop IB Hypercomputer - under development *Hobby Space Program
