Parkour on a bike: freewheel or not freewheel?
Phil Pilgrim (PhiPi)
This is strictly a mechanical engineering query. Watch this video:
····vimeo.com/4207784
Now, try to answer this simple question: does his rear wheel freewheel or not? Some clips seem to indicate yes; others, no. Frankly I'm stumped. Can it be switched on and off? Perhaps someone more experienced with this style of biking can shed some light on how these bikes are equipped.
Yeah, I know: what does this have to do with the Parallax forum? Except that it's populated with smart, interesting people who know stuff like this.
A lot of these guys use special freewheel hubs on the rear to accomplish these stunts.
Braking is done with the hand levers.
I had not seen this guy before.
Just incredible.
Welcome back to the forum! It's been awhile!
In a couple segments, he seems able to pedal backwards. In others, he's rolling forward without pedaling. Hence my perplexity. But, all engineering questions aside, his skill really is mindbendingly amazing.
Amazing!
As Beebs says, braking is done with the hand levers, and can even be obscured in a 'throttle style' hand control rather than a 'grip style' hand control. When I was doing it you only had back pedal braking.
Beau Schwabe
IC Layout Engineer
And what permits the handlebars to turn 720 degrees and still have a cable that goes to the rear wheel? (The front wheel I can understand.)
I guess I need to visit the local bike shop...
Searider
-P.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Amazing rider. I'd like to know how many times he banged the jewels...
John R.
Click here to see my Nomad Build Log
vimeo.com/4474629
360-Deg cable detangler (aka Gyro)
www.parktool.com/repair/readhowto.asp?id=144
Beau Schwabe
IC Layout Engineer
Normally the pedal pin is hexagonal or octagonal and the tolerances are much closer in the actual mechanism but I hope this will do for an explanation. Basically as the pedals turn in either direction the inertia of the rollers will cause them to lag behind the rotation of the pedal pin and they will get wedged between the inner wall of the hub and the pedal pin. Friction will keep them there unless the force is removed from the pedals. Springs are used to pull the rollers in towards the center of the pedal pin.
Forgot to mention that centrifugal force will also force the rollers out against the hub and the friction from that will also cause them to lag behind the rotation of the pin and aid in wedging them in place.
Post Edited (kwinn) : 3/10/2010 12:12:34 AM GMT
Thanks for the link. It can't get any clearer than that!
Kwinn,
That diagram makes sense. Thanks! Just to clarify, though: coaster-brake hubs have a radial tab that affixes to the frame to provide a fixed mechanical reference for backpedaling to apply the brake. Does the forward/reverse freewheel hub require something similar? Or is engagement entirely dependent on centrifugal force?
Again, for what it's worth, I still believe it's momentum and balance providing the backward movement, and when you move a bicycle backwards, you have to allow the pedals to move backwards.
If you have a bike handy, push it backwards and see what happens with the pedals.
On the diagram Kwin posted, what would keep the pins/rollers from "jamming" in place while the outer wheel was "coasting" or "freewheeling"? At any one moment, half the pins will have gravity pulling them down to the "wrong" corner when coasting.
John R.
But looking at the film again, you may be right about reverse momentum vs. pedaling in reverse.
Post Edited (Phil Pilgrim (PhiPi)) : 3/10/2010 5:13:41 AM GMT
@John R. Thats why there are springs to hold the rollers against the pedal pin when it is not turning. As long as the pedal pin is stopped or turning very slowly the rollers would be held in the center of the flat portion.
@Phil The mechanism was a bit more than just springs. There were 8 rollers around an octagonal pin or shaft and they were held in place by a plate on each end of the shaft. Those plates had 8 slots that allowed the rollers to move radially out from the shaft, and the plates could rotate slightly in relation to the shaft. I can try to draw a simple diagram if my explanation is not clear.
Not sure how brakes would be done on this mechanism except that pedaling in the opposite direction would work to slow you down. Pedals would turn though.
Post Edited (kwinn) : 3/10/2010 5:36:10 AM GMT
www.free-coaster.com/html/g-sport.html
Fast forward to 5:24 for the beginning of the description.
