Propeller Proto Board Input Voltage Limit really 9V?
Quick question.
On the Propeller Proto Board it appears that the only thing the Input voltage really touches is the 5.0 volt regulator (LM1086), which according the the National website can tolerate 30 volts on the input.
Sooo I wanted to put this board to use in a car and I'm thinking that it would be really simple to just use the 12 V (nominal) available to power this thing rather than try to get it below 9 volts first.
Can anyone think of a good reason that this would be a bad idea? Besides transients, I may put a snubber circuit on the input to protect against inductive spikes from the starter etc...
thanks.
thanks.
*Peter*
Once common solution would be to put 2-4 1N4000 series of diodes in series in the 12 V line. Each one will drop the line 0.7v.
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
Cheers
*Peter*
The problem is the higher the current the more expensive the cap gets
20mA = 5,000uF
100mA = 25,000uF
*Assuming 5.5V cut off voltage
Usually the better way is to drop the voltage first then use this circuit only on the CPU with a brown out detection circuit to handle telling the processor when the car was started.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
The main problem is heat dissipation, so in my experience it is ok as long as you don't exceed with current needs. For instance I ran 2 serial LCD, GPS and a little bit more, with no problems, as long as the backlight is disabled. Otherwise the regulator gets too hot.
Massimo
I was planning on using a AA pack of batteries as well(5 or 6 cells), I need this thing to operate while the car is off, but I would not expect my pack to last all day.
Looks like I should Drop the Voltage with series diodes, use a filter of some kind to limit spikes. And I'll need to employ a charging circuit & logic for my battery pack.
I have 2900mAh batteries and they last a lot. It depends on your requirements, but with the linear regulators in the proto board al the voltage drop is wasted, so 7.2 V nominal (6 AA NiMh) are a good option, and depending on the peripherals you'll have a lot of hour of autonomy.
Moreover if you have a current controlled charger you can expect a uniform battery behavior.
Needless to say 12V out of yor car battery are available at no cost...
have an idea of you power requiremets?
Massimo
http://en.wikipedia.org/wiki/Load_dump
Enough is never enough, unless the circuitry is active (transient/filtering & overvoltage disconnect)
as well as the mentioned passive protection(s).
or just plan on losing one occasionally, if the vehicle misbehaves.
I like the local battery 'float' idea, but the I/O MUST be addressed as well.
Mike's not overstating the problem at all, it's all there.
jr
Is is powered from a 6 NiMh 2900 mAh pack, and it works 8-10 hours.
GPS are usually not power hungry, and some of them have very reasonable current needs. I played with SD cards but I have not idea. Nonetheless I would say a SD card is not an issue. In both cases you have not alternatives..
Lexar says the current drain of their SD cards is about 35 mA www.lexar.com/digfilm/sd_specs.html, so it is equivalent to a couple of leds on.
To save power in case you need the leds, blink them in place of having them on all the time, and reduce the current across them.
Massimo
www.ereshop.com/index.php?main_page=product_info&cPath=75&products_id=188
They are low-cost switching regulators that are drop in replacements
for linear regulators.
With a 200 volt spike lasting 1uSec the output only sees a roughly 1volt spike. I should be able to get the big inductor from the local university's ECE store.
Anyone know how long the inductive spike actually lasts for a typical starter motor? Or what the voltage could go to? I'm guessing that the insulation is usually 300v, so it must not go above that.
Load dump though can spike the supply up to 120V for 400ms which the transzorb and polyswitch will handle to protect the electronics as well as other sustained overvoltage conditions.
*Peter*
