Strange Problem with ir detect pairs
I'm quite baffled about this and can't find any info in the forums thus far.
I have a boebot using bs2 and a board of edu with bs2sx. The boe is wired for a left and right pair of ir detection sensors like whats made in chapter 7 of "robotics with the boe bot v 2.2". I have 3 random ir detectors pulled from vcr, dvd, and sat reciever. Because of the randomness of the parts the left was acting a little erratic, so I ripped apart a dvd player to harvest another. I wired the test circuit to my bs2sx w/homework board and proved that the new reciever/ir led·works perfectly.
The weirdness is that even though the wiring and programming is exactly·the same (except pin outs) on my boe bot as on the homework board, when I put the new reciever on either left or right positions of the boe bot it reads low and does not change unless I pinch it between my thumb and forefinger (it should be 1 until it encounters an object then changes to 0). When I put the good one back in either position it works perfectly. Likewise the new reciever works perfectly on the board of education. When I take the good one from my boe and put it to the board of edu.·it will read high and·never switch to low when·I put my hand in its way or pinch it like the other.·Once again the circuit wiring is exactly the same.
Could this be some difference between bs2 and bs2sx?
Any help would be delightful.
Another difference between the BOE and Homework boards is that the Homework board has 220 Ohm resistors in series with all the I/O pins and this can affect the current available for LEDs and possibly the voltage read by the Stamp from the IR detectors. This all depends on exactly how you have things hooked up (which you haven't described in enough detail).
Thanks for the response. I figured it had to be a problem with the two different stamps. You shoved me in the right direction. Playing around with the frequency on my bs2 I got the little bugger working just peachy at 3000Hz. That number may not be exactly as it should be for all I know, but it works. I haven't yet read the resource you mentioned to figure it out properly, but thanks for showing me where to look.
