Toggling or Remains at 3.3V
Tommm
Is there A way to program the BS2, so it will sample A signal Pin to determine if the pin is toggling or remain at 3.3v? For example, once the I/O changes state (low/high); you can wait for 4 seconds and sample the I/O pin again; if it's HIGH. Then Run this program
(High 14 pause 100 Low 14 pause 100). If its toggling run this program (High 15 pause 1000 low 15 pause 1000).
Tommm
Tommm
Tommm
www.parallax.com/tabid/535/Default.aspx
www.parallax.com/tabid/440/Default.aspx
Tracy Allen
www.emesystems.com
