Help with SMS - Specified digit of number — Parallax Forums
Robert KRobert K Posts: 6
edited 2010-03-07 02:49 in BASIC Stamp
I am tryling to use Basic Stamp to send SMS. Cell phones normaly accept PDU format, so I need to convert data to PDU. Please look at program below. The problem that I have is: putting·digits ·directly into the program - everything is working great, when I am trying to take a number and use specified digits, I am getting some non-sens.
I am sure solution , like always is rather easy, but for some reason I can not see that. Please help ;
Robert
PDU·· VAR Byte(7)
CH··· VAR Byte(8)
Value VAR Word
Value = 1234
CH(0)=Value DIG 3
CH(1)=Value DIG 2
CH(2)=Value DIG 1
CH(3)=Value DIG 0
CH(4)="5"
CH(5)="6"
CH(6)="7"
CH(7)="8"
' PDU shift routine
PDU(0)=(CH(1) << 7)+(CH(0) >> 0)
PDU(1)=(CH(2) << 6)+(CH(1) >> 1)
PDU(2)=(CH(3) << 5)+(CH(2) >> 2)
PDU(3)=(CH(4) << 4)+(CH(3) >> 3)
PDU(4)=(CH(5) << 3)+(CH(4) >> 4)
PDU(5)=(CH(6) << 2)+(CH(5) >> 5)
PDU(6)=(CH(7) << 1)+(CH(6) >> 6)
'PDU OUTPUT (should be :· 31 D9 8C 56 B3 DD 70
DEBUG HEX2 PDU(0),HEX2 PDU(1),HEX2 PDU(2),HEX2 PDU(3),HEX2 PDU(4),HEX2 PDU(5),HEX2 PDU(6),CR
    edited 2010-03-06 16:30
    Robert K said...
    What nonsense are you getting? The program is probably doing exactly what you are telling it to do, but you are telling it to do something other than what you want. Computers work that way.
    - Stephen
  • Robert KRobert K Posts: 6
    edited 2010-03-06 16:48
    I am getting :
    01 C1 80 50 B3 DD 70
    which after conversion back to text is :
    £$¥è567
    Should be :
    which convert to (cottected values)
    1234567
    So first 4 numbers are translated wrong, the one that I left unchanged are ok
    edited 2010-03-06 16:52
    Value DIG 3
    This gives you a value from 0 to 9, not an ANSI character.
    Try: (Value DIG 3) + "0"
    Thanks that works !!!,
    Robert
