Hall Sensor and 74HC165 on a Propeller
I would like to use a Hall Sensors as a switch that are connected to a 74HC165 on a Propeller. Could anyone recommend an inexpensive Hall Sensor and give me an idea as to what additional hardware I might need to set this up. I will be driving 32 bits (4) chips so I will need 32 of these sensors. They will be within 1.6" of each other. So I need a very focused sensor that will not pickup the magnet 1.6" away.
uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&tfgSearch=Y&N=4294954024&searchTerm=Hall%20Effect%20Sensors&cm_sp=Predictive_search-_-Pedictive_search-_-Hall%20Effect%20Sensors
The digital output ones have a 5V output.
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 3/5/2010 6:52:24 PM GMT
·parallax has melexis hall effects for as inexpensive as anyone, unless they are out of stock. mouser and digikey have them for $5 and $7 respectively. i just built one and
with bs2 i was faced with using count or pulsin. count relies on a time frame and that is a negative. pulsin demands a very quick response and mine was not quick as it involves a slow moving wheel, so neither really fit the bill.
if you go with the melexis, they are expensive.· see the datasheet on digikey to see the connects, which include caps, resistors, and i used indicator leds.
the ic parallax recommends is a buffer and a +5 volt input gives a low output. check that out also on the datasheet at digikey.
best of luck. jim
bahamajim@gmail.com
The smarter I get, the more I understand I don't know!
