Stingray motor/motion control object posted in obex — Parallax Forums
Nico SNico S Posts: 9
edited 2010-04-09 13:09 in Robotics
Hi all,
As i started recently with the stingray robot and the propeller chip programming, my first project was to create a dedicated·object for easy control of the movements.
The object is written in SPIN and PASM, and doesnt use other objects.
The PASM code doesnt make use of counters to generate the PWM signal as i want to use the counters for future wheel/motor encoders.
To control the motors the object generates a 1Khz PWM signal.
It supports Forward, backward, turning, rotation movements with speed and ramping control.
As this is my first real object please feel free to comment, give tips/hints on the code.
The object can be found under Stingray motor / motion control in the motor control section.
Have fun !
Best regards,
Nico Schoemaker
  • mugurmugur Posts: 105
    edited 2010-03-05 00:36
    Great news. Thank you.
    images-team.ro
    edited 2010-03-05 04:17
    Good news, Nico.
    Does anybody have their Stingray driveable by IR remote?
    edited 2010-03-05 18:17
    Nico,
    It is nice to see customer contributions. This month has seen the start of the Encoder object for the Stingray. Once I have sufficient progress I will start a thread on that.
    Parallax Engineering
  • WhitWhit Posts: 4,191
    edited 2010-03-05 19:13
    It sure would be nice if everyone who added a Stingray object would include the word "Stingray" in the title - like Nico did. This would make search's easy.
    Great work Nico!
    Whit+
  • Nico SNico S Posts: 9
    edited 2010-03-05 22:36
    Thanks !!
  • hover1hover1 Posts: 1,929
    edited 2010-03-05 23:22
    It will be here soon. Jim E is working on it
    Jim
    Whit said...
    Great work Nico!
  • Chad_CChad_C Posts: 2
    edited 2010-04-08 02:33
    Good Code.
    The only issue I was having with it was that I was really trying have the ability to control the motor speeds individually. I tried making a new PUB called TurnWheel(LSpeed, RSpeed) where 'LSpeed' was the left motor speed and 'RSpeed' was the right motor speed. For some reason, when executing TurnWheel with LSpeed = -30 and RSpeed = 30, the Left motor just stops while the right motor keeps spinning at the proper speed. I tried going through the PASM code. I could follow the code down to where the C flag should be set but I had issues fixing it.
    Using the PUB code below to control the motor speeds individually, is there anything that I'm missing or why this code will not work? I have not modified the assembly portion of the code or any of the other routines in the SRMotorControl.spin. I tried uploading the .spin code as an attachment just in case.
    Any Help would be appreciated.
    Chad_C
    PUB TurnWheel(LSpeed,RSpeed)
    if (LSpeed == 0) AND (RSpeed == 0)
    MoveForward(0)
    repeat until vCommand.byte[noparse][[/noparse]0] == 0 'Wait until current getCommand is processed by the cog
    LSpeed <#= 100 'Limit Speed to 0..100
    LSpeed #>= 0
    RSpeed <#= 100 'Limit Speed to 0..100
    RSpeed #>= 0
    vCommand.byte[noparse][[/noparse] 1] := LSpeed 'Set leftspeed to LSpeed
    vCommand.byte[noparse][[/noparse] 2] := RSpeed 'Set rightspeed to RSpeed
    vCommand.byte[noparse][[/noparse] 0] := 1 'Update flag
    Post Edited (Chad_C) : 4/8/2010 2:38:24 AM GMT
    edited 2010-04-08 02:57
    These lines are limited the values to between 0 and 100:
    LSpeed #>= 0
    RSpeed #>= 0
    So your -30 is getting clamped to 0. Change those 0's to -100's and see if that works?
    Check out the Propeller Wiki·and contribute if you can.
    edited 2010-04-09 00:10
    Thanks for the response. I'm an idiot LOL. I can't believe I overlooked that; it was driving me nuts. Changing the LSpeed and RSpeed values did fix it.
    Thanks Again,
    Chad_C
    Chad_C,
    Glad you posted! - no telling how many people you helped. No question is a dumb question. Glad you are up and running.
    Whit+
