USB Drive Archive Help Please!
I have a pc with Windows XP and several various brand
large capacity USB drives.
When I drag a parallax archive folder over to copy it,
after a few thousand files, it stops and gives the error
that the file name is too long.
I finally figured out that it's the path name that's too
long. That's because I have a half million files.
It's too much to try and shorten the names. It will lose
the identification feature.
When the error comes up, and it stops copy, there is
no way to continue the copy, so I can never copy a
folder completely.
As files increase on my computer, and the need to
copy folders is important, a solution is needed.
There are no backup programs that I have found
which I can trust. They all had some similar problem.
The programs that continued to copy, merely bypassed
the files with the errors, so much information was lost.
Any suggestions?
Thank you in advance,
humanoido
folder completely.
Any suggestions?
humanoido
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
But I'd divide them up into groups instead of trying to zip the entire half million. If you can identify some as files you'd hardly ever access, you could zip them and move them completely off your server; otherwise maybe you could split them up alphabetically or by date or something.
if a few years down the road, will it still exist? I would want
to avoid the scenario where a half million files are zipped and
no way to unzip.
humanoido
- Stephen
volumes of data. But how many DVDs are needed for a half TeraByte
of files? My guess is the read and write rates of these drives are
somewhat slow.
humanoido
John Abshier
Post Edited (John Abshier) : 3/6/2010 4:33:56 PM GMT
I've got about a tenth that many files, about 50K files, using about 9 gig of space, that have accumulated over the years, that I keep in a folder on my "E" drive, and Windows has no problem copying the entire folder to an alternate drive with just a drag and drop of the folder. It takes about 10 or 15 minutes to do the backup.
Why are you getting a "too long filename" error? If you're violating the storage parameters of the destination drive, maybe by nesting files too deep in layers of folders, then maybe all you need to do is flatten out your storage design and you could use your USB drive like you had tried.
Parallax microcontroller code in the lifetime of your PC, since ...
-I doubt so much code has been written for all of these microcontrollers.
-If the data was all video, it would take you well over a month to watch all of it.
-Your PC will wear out way before you utilize a half terabyte of microcontroller code.
-I can't even manage a closet full of backups from the years when the BSoD MTBF rate was once per week,
and that isn't even half a terabyte.
-I recommend copying what you are using, hold the originals as backup, until you get a holographic storage drive.
Where is all that Parallax microcontroller code in your archive collection coming from anyway, I wonder out loud?
I should be typing in Spin now.
Coming soon. My open Propeller Project Pages and favorite links index.
