Propeller USB HUB
I am finding that the propeller is a great chip. People are asking me more question and asking me to do more with it. One frequent question is if a cog on the propeller can be arraigned as a USB HUB. Any one heard of this and do you think it is possible?
...Looks like you would have to specify the Device class, pick a Signaling rate (maybe USB 1.0) , Then use the Data packets correctly.
Leon Heller
Amateur radio callsign: G1HSM
Why would you want to? You can buy entire USB Hub-on-a-chip solutions for far less than the cost of the propeller chip alone. Use the right tool for the right job.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
