Need Help with SX28 code efficiency (SHIFTOUT, READ, temp variables?, etc.) in — Parallax Forums
T&E EngineerT&E Engineer Posts: 1,396
edited 2010-03-04 18:11 in General Discussion
I have working code but need to have it run faster·and more efficient. How can I improve this
(Mainly trying to have a subroutine or something for the SHIFTOUT statements and possibly READ statements - but don't know if I can call out Cpin and Dpin pin #s) What about combining the CpinX into a single one(?) like I did with A, B, and Latch:
' IO Pins
A  PIN RA.0 OUTPUT   ' A line (A pin 9)
B  PIN RA.1 OUTPUT   ' B line (B pin 11)
Latch  PIN RA.2 OUTPUT   ' latch outputs (STB pin 3)
Cpin1  PIN RB.0 OUTPUT   ' shift clock1 (CLK pin 1)
Cpin2  PIN RB.1 OUTPUT   ' shift clock2 (CLK pin 1)
Cpin3  PIN RB.2 OUTPUT   ' shift clock3 (CLK pin 1)
Cpin4  PIN RB.3 OUTPUT   ' shift clock4 (CLK pin 1)
Cpin5  PIN RB.4 OUTPUT   ' shift clock5 (CLK pin 1)
Cpin6  PIN RB.5 OUTPUT   ' shift clock6 (CLK pin 1)
Dpin1  PIN RC.0 OUTPUT   ' shift data1 (DG pin 7)
Dpin2  PIN RC.1 OUTPUT   ' shift data2 (DG pin 7)
Dpin3  PIN RC.2 OUTPUT   ' shift data3 (DG pin 7)
Dpin4  PIN RC.3 OUTPUT   ' shift data4 (DG pin 7)
Dpin5  PIN RC.4 OUTPUT   ' shift data5 (DG pin 7)
Dpin6  PIN RC.5 OUTPUT   ' shift data6 (DG pin 7)
Main:
HIGH A      ' Turn off displays
HIGH B
For alpha = 0 TO 23    ' 0 - 23 for 1st odd row display
  READ ODD_ROW_1A + alpha, pattern  ' read in the data
  SHIFTOUT Dpin1, Cpin1, MSBFIRST, pattern       ' send the bits
  READ ODD_ROW_2A + alpha, pattern  ' read in the data
  SHIFTOUT Dpin2, Cpin2, MSBFIRST, pattern       ' send the bits
  READ ODD_ROW_1B + alpha, pattern  ' read in the data
  SHIFTOUT Dpin3, Cpin3, MSBFIRST, pattern       ' send the bits
  READ ODD_ROW_2B + alpha, pattern  ' read in the data
  SHIFTOUT Dpin4, Cpin4, MSBFIRST, pattern       ' send the bits
  READ ODD_ROW_1C + alpha, pattern  ' read in the data
  SHIFTOUT Dpin5, Cpin5, MSBFIRST, pattern       ' send the bits
  READ ODD_ROW_2C + alpha, pattern  ' read in the data
  SHIFTOUT Dpin6, Cpin6, MSBFIRST, pattern       ' send the bits
NEXT alpha
PULSOUT Latch, 1                               ' transfer to outputs
LOW B      ' turn on odd rows
PAUSEUS DelayTime
HIGH A      ' Repeat again for even rows
HIGH B      ' Turn off display
For alpha = 0 TO 23    ' 0 - 23 for 1st even row display
  READ EVEN_ROW_1A + alpha, pattern  ' read in the data
  READ EVEN_ROW_2A + alpha, pattern  ' read in the data
  READ EVEN_ROW_1B + alpha, pattern  ' read in the data
  READ EVEN_ROW_2B + alpha, pattern  ' read in the data
  READ EVEN_ROW_1C + alpha, pattern  ' read in the data
  READ EVEN_ROW_2C + alpha, pattern  ' read in the data
NEXT alpha
LOW A      ' turn on the even rows
PAUSEUS DelayTime
 GOTO Main
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2010-03-04 16:05
    "Faster and more efficient" to me means do it in assembly.
    I don't think with SX Basic you can do the pin assignments for SHIFTIN/OUT as variables. I know you definitely can not for SERIN/OUT
    -MH
  • JonnyMacJonnyMac Posts: 9,809
    Look at the code created by SHIFTOUT and create a custom version that allows a variable pin -- it's not that hard. What you'll want to do is take the pin # and turn it into a mask that can be toggled.
    Jon McPhalen
    Hollywood, CA
