SX52 Debug not possible - all tries (chips, SX-keys) without success
I tried 3.3.0, 3.5BETA, 3.2.3 and SX52key.exe (yes, an old one).
I have two PCB's, same layout, two different SX52 chips.
On the PCB are just the 10k resistor and some block condensators, SMD only.
Basically I used SX-Key Rev. F in the past to flash approx. 1,000 chips.
I bought a new USB SX-Key Rev. B yesterday.
And I used several types of power supplies.
I know that
My device section is: sx52, oschs3
After programming the status shows up with "Running" and
all buttons except Reset are gray.
I have no clue what to do...
Is there any documentation about the signals I could trace with a scope?
Thanking in advance for every advice.
I know that
· If you have a resonator installed, you'll have to remove it to debug.
· The chip WILL program will the resonator installed, but it will not debug.
· Also, the older serial SX-Key is more robust in debugging, so I would use that it you have one.
· P.S. If you do use the serial version the SX52 MUST be powered with 5 volts.
Bean.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
On the PCB are short wires to connect the SX-key.
I removed one SX52 and replaced it with a new one.
I used a lead-free flux dispensing pin several times
because flux can cause malfunction.
PS: In the first post I started a sentence with "I know that", nonsense.
CMOS Crystal Oscillators only.
Surely it's not connected and missing on the newest PCB for testing.
Is there a picture of your board that you can post? What about a schematic?
You mention a 10K resistor but there isn't anything stating how it is connected. Is that just a pull up line on the reset?
I shortened the distance from SX-Key to the SX52 a little bit,
let me say 1/2 inch. The distance is very critical, I knew it
from experience in the past. Another PCB layout for another
design works with Debugging and it gave me the hint to keep
the focus on the distance.
Tipp:
For everyone who uses own PCB's (industrial types included)
keep the distance to the SX-Key as short as possible.
Now I have one SX-USB-Key left, grrrml...
