passing through serial
I want to use a ProtoBoardUSB to connect to any number of 3v3 line level serial consoles, like for the Zipit, or my wgt634u. For some reason, I just get garbage out, when captured through Brad's spin tool looks like this:
instead of like this:
Which is what get when using my propplug.
Here's my program:
I also get zero's when I should get nothing. Anybody know what I am doing wrong?
I have tried %1000 and even %0001 in the device start configuration bits, but to no avail.
Any help would be appreciated.
Doug
80 E8 EC 2D 0F 25 98 CA F8 B4 5D AD B0 2F 56 A4 53 05 82 DE 2F 35 80 44 26 53 13 09 CC FC 98 BC 26 9D 48 80 54 4B DC A2 33 48 21 F0 98 1C 4C 26 90 48 50 85 51 E6 F2 FB BA DC 2D 52 EC FC EC B4 5B 00 C6 EF B6 B6 FD D6 22 A4 81 60 40 8C 6F 90 86 80 DE F0 B7 8C AA 75 82 E2 2D 87 00 62 B3 E0 B7 06 6B 8C 80 CA F9 B0 7C E7 E4 F3 35 14 A3 1C 7B 13 2D 18 14 86 B0 5B 2D EC 98 97 4C 89 F3 C9 7F 07 25 E2 26 0C 44 F0 84 34 F2 B9 7F 87 45 1E 8F E6 B3 7C 0F 8C 16 B5 60 1B 2C FB A4 FC E6 B3 0F 8C 16 B5 60 AC A4 D0 DC E6 B7 7C 0F 00 A6 A2 2C 96 8B D5 00 FE F0 B6 90 84 E5 F8 DA A2 33 5D F0 E3 B4 DC 86 F3 6B 1A 87 A1 EF 45 00 CC B9 85 13 9C FB 86 C2 E1 B7 0F A0 B7 1B 2D 55 90 D2 B7 51 57 65 DA FB 86 C2 A2 F8 29 13 B0 5A 4F 00 7A 66 A2 EC E0 B9 43 E0 FB B2 3B 6F 6F 29 FF EC B7 3B 18 14 43 B4 2C 15 04 C1 18 14 BB 13 3C E5 2D 00 7A A0 92 9A C2 FB 53 00 7A A0 98 27 03 53 A9 40 72 9D 1C 21 E0 FB BA 5C 07 A4 67 45 98 FB B0 2D 13 29 25 9E EE EC B2 5B AE CC FC B9 BF 7C 17 E5 70 40 E0 B8 5C 21 E0 FF A4 54 29 29 4A 81 10 87 94 AA 55 99 C4 FF B6 FF 2C 97 E4 E4 F3 35 14 BA 59 AD EC 7A 98 21 E0 00 00 00
Aeronix Zipit2 Version 1.00 7-10-2007 blob version 2.0.5-pre3 for Intel HCDDBBVA0 (Mainstone) Copyright (C) 2007 Jan-Derk Bakker and Erik Mouw blob comes with ABSOLUTELY NO WARRANTY; read the GNU GPL for details. This is free software, and you are welcome to redistribute it under certain conditions; read the GNU GPL for details. RTC Clock Enabled. Memory map: 0x02000000 @ 0xa0000000 (32 MB) LCD: init ...Loading blob from flash . done Loading kernel from flash ......... done Autoboot (0 seconds) in progress, press any key to stop Autoboot aborted Type "help" to get a list of commands blob>
Here's my program:
{{3vSerial.spin}}
' Eventually this will be a program to use the prop dongle as a 3.3v port to
' connect to a WGT634u and similar 3.3v serial ports
CON
_clkmode = xtal1 + pll4x 'Set for slow crystal
_xinfreq = 5_000_000 'Use 5 MHz accurate crystal
conTx = 30 ' Boot serial port(USB FTDI) transmit pin
conRx = 31 ' Boot serial port(USB FTDI) receive pin
devTx = 1 ' 3v target serial port transmit pin
devRx = 0 ' 3v target serial port receive pin
OBJ
console : "FullDuplexSerial" ' Serial port for console
device : "FullDuplexSerial" ' Serial port for device
VAR
Long console2deviceStack[noparse][[/noparse]20]
PUB main | err, s
console.start(conRx,conTx,%0000,115200) ' Start console serial port
device.start(devRx,devTx,%0000,115200) ' Start device serial port
CogNew( console2device, @console2deviceStack )
repeat 'run device2console in main cog
device.tx(console.rx)
PRI console2device
repeat
console.tx(device.rx)
Doug
Doug
