(Untitled)
Hey! O have been thinking/reading a lot about single board computers and PC controlled robots. And I was wondering just how make and work with SBC controlled robots. Is it possible to just put a laptop onto a base and controll the robot with that?Thanks,
SB 3:16
SB 3:16
Signature space for rent!
Send $1 to CannibalRobotics.com.
One thing I found out recently is that the VGA port contains an I2C bus and people are using that port to access sensors as well.
SB 3:16
It might even be possible to interface a mini-itx board to a BS2 board through the serial port. The BS2 could handle all the motors and sensors while the mini-itx does all the deep thinking.
Thanks again,
SB 3:16
A laptop motherboard would work and I know someone who hacks old laptops into embedded systems. But as Mike Green pointed out you'll need to know what you are doing.
There are also gumstix which are ARM based SBC's and seem even more power efficient, but they cost an arm and a leg.
