DS1302 Back-up Battery Charger — Parallax Forums
Nick WaldvogelNick Waldvogel Posts: 71
edited 2010-03-04 22:26 in BASIC Stamp
I have been working with a DS1302 and I can't seen to get the coding right to turn off the charging output. I read the data sheet and it states that the output is off by default. However, I somehow got it turned on because I have a output voltage of 1.20v on the back-up pin. I want to be able to turn it off so that I don't have trouble with non-rechargeable batteries. I just need a shove in the right direction. Thanks for any input.
Nick
    edited 2010-03-04 00:26
    Here is the table that you need
    Trickle Charge values
    Tric····· CON %10010000
    OFF······ CON %11110000 'turns off trickle charge
    D1R1····· CON %10100101 '1 diode 1 resistor 0.7v 2k ohms
    D1R2····· CON %10100110 '1 diode 2 resistor 0.7v 4k ohms
    D1R3····· CON %10100111 '1 diode 3 resistor 0.7v 8k ohms
    D2R1····· CON %10101001 '2 diode 1 resistor 1.4v 2k ohms
    D2R2····· CON %10101010 '2 diode 2 resistor 1.4v 4k ohms
    D2R3····· CON %10101011 '2 diode 3 resistor 1.4v 8k ohms
    Temp = D2R3············ ' *** Edit this variable ***
    RTCCmd = TRIC
    How ever you would be better off to us a ONE FARD Supper Cap work much better I have used both
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
  • Nick WaldvogelNick Waldvogel Posts: 71
    edited 2010-03-04 03:08
    Thanks for the reply Sam
    I have tried to use te values you provided. I still can't get it to work. Maybe I'm testing it wrong? I'm testing with a DVM from Vss to pin #8 of the DS1302 with the battery not installed. I thought I was getting 1.20v but as I test more and more I find that the voltage is moving around..... I have seen voltage as high as 4.20v and the lowest I can get now is 1.7 volts. I have stripped the code down to what I believe is the bare minimum to get it to change the charger settings.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    '------- Trickle Charge values ---------------------------------------------
    Tric      CON %10010000
    OFF       CON %00001111 'turns off trickle charge
    D1R1      CON %10100101 '1 diode 1 resistor 0.7v 2k ohms
    D1R2      CON %10100110 '1 diode 2 resistor 0.7v 4k ohms
    D1R3      CON %10100111 '1 diode 3 resistor 0.7v 8k ohms
    D2R1      CON %10101001 '2 diode 1 resistor 1.4v 2k ohms
    D2R2      CON %10101010 '2 diode 2 resistor 1.4v 4k ohms
    D2R3      CON %10101011 '2 diode 3 resistor 1.4v 8k ohms
    Temp = D2R2            ' *** Edit this variable ***
    RTCCmd = TRIC
    ' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
    DataIO          PIN     0               ' DS1302.6
    Clock           PIN     1               ' DS1302.7
    CS1302          PIN     2               ' DS1302.5
    ' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
    CWPr            CON     $8E             ' Write Protect Register
    WPr1            CON     $80             ' Set Write Protect
    WPr0            CON     $00             ' Clear Write Protect
    ' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
    reg             VAR     Byte            ' Read/Write Address
    ioByte          VAR     Byte            ' Data To/From DS1302
    Temp      VAR Byte
    RTCCmd    VAR Byte
      reg = CWPr                            ' Initialize DS1302
      ioByte = WPr0                         ' Clear Write Protect
      HIGH CS1302                           ' Select DS1302
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg, ioByte]
      LOW CS1302                            ' Deselect DS1302
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]%10010000, %00001111]
     STOP
    Nick
    edited 2010-03-04 03:25
    I now relize that when I change the value highlighted I get a voltage change on pin #8. I get 4.10v with a value of %10101011 and 1.60v with %10101011.
    I'm concerned that even with a value of %00001111 it should turn off the charging output but I still get a voltage above 1 volt. Maybe it's nothing to be worried about?
      SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]$90, [b]%10101011[/b]]
    Nick
    edited 2010-03-04 03:56
    With even more testing I found that the mA are changing as they should, based on the formula provided on the data sheet, with a battery installed. I believe that the battery needs to be low on voltage to see the voltage change. Everything seems to be falling into place.
    Make sure that you only use about 100 millamp hour batterys if the millamps are more than that··they may not charge all the way up
    The ones that a cordless phone battery pack this is what I would
    That why I was saying that I use supper caps
    Sam
    Post Edited (sam_sam_sam) : 3/4/2010 10:33:20 PM GMT
