Accelerometer H48C with ATmega16
Hi!
I've been trying to communicate with my accelerometer for some time now. It is parallax's accelerometer module h48c with built-in ad-converter (MCP3204).
the module has a single data-in,data-out pin.
for basic stamp users the data is easily read with the
commands SHIFTIN and SHIFTOUT.
example basic stamp code:
so ive tried to make a similar code for the avr with help from bobgardner who supplied me with a example code.
but i still cant get it to work.
im wondering if the clockpulses must be more accurate delays or something.
i was hoping anyone of you guys could help me find whats wrong.
LOW CS SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, axis\3] ' select axis SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]axCount\13] ' read axis voltage counts HIGH CS
#include <avr/io.h>
#define DIOOUT() DDRC |= 0x40 //PC6
#define DIOIN() DDRC &= ~0x40
#define CSHI() PORTC |= 0x10 //PC4
#define CSLO() PORTC &= ~0x10
#define DIOHI() PORTC |= 0x40 //PC6
#define DIOLO() PORTC &= ~0x40
#define CLKHI() PORTC |= 0x80 //PC7
#define CLKLO() PORTC &= ~0x80
#define NOP() asm("nop")
void clock(){ //Clockpulse
CLKLO();
NOP();
CLKHI();
NOP();
int main() {
int ch;int bit;int msk;int dat;
DDRC=0xFF;
PORTC=0xFF;
DIOOUT(); //Set DIO pin input
CSHI(); //Deactivate AD
ch=0b11000; //Channel0 (x-axis)
while(1){
CSLO(); //Activate AD
//---ShiftOut---
msk=0b10000;
for(int i=0; i<5; i++){
bit=(ch & msk) != 0;
if(bit){DIOHI();} else {DIOLO();};
msk>>=1;
clock();
//---ShiftIn---
DIOIN(); //Set DIO pin Input
clock(); //Sampling time
clock(); //Null bit
dat=0;
for(int i=0; i<12; i++){
clock();
dat<<=1;
bit=(PINC & 0x40) != 0;
