Help with a VMusic2 module
We are working on a senior design project in which we are using a VMusic2 module to play mp3 files through our BS2p40. Originally we had a BS2 micro-controller, however we needed more I/O pins. This is why we changed to the BS2p40 with the understanding that our code would stay the same. However, we are having trouble with outputting the sound with the BS2p40. The BS2 played the files fine with the SEROUT 0,84,[noparse][[/noparse]"VPF mrjon.mp3",CR] command, but the BS2p40 is not outputting anything to our amplified speaker. If you can help with this please let us know.
The VMusic2 is a great module.
Jim
http://forums.parallax.com/showthread.php?p=792332
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Why did you use the VMusic2 as opposed to the DLP-VLOG·?
Jim
Andrew Williams
WBA Consulting
