ICCV7 won't start (Win Vista) — Parallax Forums
fiddejohfiddejoh Posts: 6
edited 2010-10-20 17:09 in Propeller 1
Hi, I recently bought my first Propeller and thought I'd check out ICCV7 for Propeller.
I downloaded the 45-day trial from ImageCraft and installed it on my Vista machine. When I launch the program it won't show though, I see the process running under task manager but I see no window.
Haven't found any info regarding this so I thought I'd check here. Has anyone seen this problem before?
/ Fredrik
  • RsadeikaRsadeika Posts: 3,849
    edited 2010-03-03 10:49
    Within the last couple of weeks, I installed the 45-day trial version on my Windows 7 64-bit system, and I did/do not have any problems with the program starting or running. I would suggest uninstalling, and running the installation procedure again. I really thought I would have some kind of problem because of the 64-bit system, but to my surprise, no problem whatsoever.
    Ray
  • fiddejohfiddejoh Posts: 6
    edited 2010-03-03 11:35
    Ok, good to hear that it works under Win 7 as well [noparse]:)[/noparse]
    I will try to re-install it and see if it works. Thanks for your reply.
    / Fredrik
    edited 2010-03-03 13:42
    I got it working, it took about 1 minute to launch the application.. Hopefully that was just the first time.
  • Steve5591Steve5591 Posts: 2
    Try running the program in windows xp service pack 3 compatability mode by right clicking the exe file and going to the compatability tab. If this does not work, uninstall the program and reinstall it in the same compatability mode you just tried. Best of luck!
