Propeller communication speed
Hi All,
I am new to propeller. I need some suggestion for how to do fast PC to Propeller, inter propeller·connection. I do apologies if the question has been asked, but I real have no ideal which way is the go. ··I also want to know what is the maximum speed we can achieve for those connection. Thanks··
It depends how fast your talking.
FTDI devices can do a maximum of 2Mbps(1Mbps stable)(prop to pc), prop to prop can be done at 250Kbps easily,... it is possible to get 8mbps prop to prop using some of the methods people talk about in the forums.
What are you trying to do?
http://forums.parallax.com/showthread.php?p=691952
*Peter*
I am doing a project to run 24 to 96 IMS MDrive stepper which have driver integrated. The only control which I need is clock input to drive micro-steps. The multiple counters of propeller make it easy to drive those Steppers. I am trying to use one propeller as master node which get stepper speed data from PC and some leave nodes for drive steppers.
Is there any post Or object show how viewport' high speed communications work?
There's a review of ViewPort in my signature and a link to download a free 30 day trial. Should be ideal for your project. Here's a short not on using ViewPort to drive motors and control speed via PID.
http://hannoware.com/viewport/motor.php
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Thanks for the information. We definitely consider using viewport in our prroject. We directly control stepper speed by send clock which indicate micro-steep(each clock plus is 1 micro-steep ) there is no need for PID and I already finished those parts. My problem right now is how to do high speed (PC to prop) and (inter prop with address) connections. Any suggestion?
Hanno
