Please help me fix this code
Hello all, I am new to this forum so sorry if this has been covered somewhere. I have a homework assignment which entails that I can do whatever I want with what I have in this custom basic stamp 2 kit. It's pretty much the "whats a microcontroller?" kit with a few extra goodies. What I decided to do is do the lightmeter project with the 2x16 serial lcd as the display, a button to start and stop the lightmeter, and a speaker to play sounds for on/off events and for different time settings from RCTIME. I had it working perfect but when I came back to mess with it, the program tells me I have data that occupies the same location as the program. I've narrowed it down to the intro message (which has an animation) but cannot figure out what the heck I changed with it that has caused this problem. If any one of you stamp 2 pros could give me some insight, I would greatly appreciate it. This assignment is due Thursday, March 4, so if that date has passed, don't worry bout it. Anyways, here's my super long code:
Post Edited (kicknitinkc) : 3/2/2010 6:54:20 AM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
'----------CONSTANTS-----------
button1 PIN 3 ' button pin
TX PIN 15 ' serial output to LCD
LcdBaud CON 32 ' LCD baudrate = 19,200
LcdCls CON $0C ' clear LCD (use PAUSE 5 after)
LcdBLon CON $11 ' backlight on
LcdBLoff CON $12 ' backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdCC0 CON $F8 ' define custom char 0
LcdCC1 CON $F9 ' define custom char 1
LcdCC2 CON $FA ' define custom char 2
LcdLine1 CON $80 ' move to line 1, column 0
LcdLine2 CON $94 ' move to line 2, column 0
midtime CON 10000
'------------VARIABLES-----------
idx1 VAR Byte
idx2 VAR Byte
idx3 VAR Byte
idx4 VAR Byte
s VAR Byte
time VAR Word
newchar VAR Byte
'-----------EEPROM DATA----------
CC0 DATA LcdCC0, 14,21,31,10,14,14,0,0
CC1 DATA LcdCC1, 14,21,31,10,14,0,14,0
CC2 DATA LcdCC2, 14,21,31,10,14,0,0,14
msg2 DATA " Mechatronics "
msg3 DATA " is AWESOME!! "
'--------------power on song-----------
PAUSE 250
FREQOUT 14, 75, 2093
FREQOUT 14, 75, 2637
FREQOUT 14, 75, 3136
FREQOUT 14, 75, 2349
FREQOUT 14, 75, 2793
FREQOUT 14, 75, 3520
FREQOUT 14, 75, 3951
FREQOUT 14, 25, 4186
FREQOUT 14, 25, 4086
FREQOUT 14, 25, 4286
FREQOUT 14, 1000, 4186, 4191
HIGH TX ' setup serial output pin
PAUSE 100 ' allow LCD to initialize
FOR idx1 = 0 TO 26 ' download 3 characters
READ CC0 + idx1, s ' get data from table
SEROUT TX, LcdBaud, [noparse][[/noparse][b]s[/b]] ' send to LCD
NEXT
SEROUT TX, LcdBaud, [noparse][[/noparse]LcdBLoff, LcdOn1, LcdCls]
PAUSE 250
'------------intro message-----------------------
'*************fault is in here somewhere***************
FOR idx3 = 0 TO 15 ' scroll across line
READ (Msg2 + idx1), newChar ' read new character
FOR idx2 = 0 TO 4 ' animate a current position
LOOKUP idx2, [noparse][[/noparse]0, 1, 2, 1, newchar], s
SEROUT TX, LcdBaud, [noparse][[/noparse](LcdLine1 + idx1), s]
PAUSE 50
NEXT
NEXT
FOR idx4 = 0 TO 15 ' scroll across line
READ (Msg3 + idx1), newChar ' read new character
SEROUT TX, LcdBaud, [noparse][[/noparse](LcdLine2 + idx1), s]
PAUSE 50
NEXT
NEXT
FOR idx1 = 1 TO 10
SEROUT TX, LcdBaud, [noparse][[/noparse]LcdBLon]
PAUSE 75
SEROUT TX, LcdBaud, [noparse][[/noparse]LcdBLoff]
PAUSE 75
IF idx1 = 10 THEN
PAUSE 250
ENDIF
NEXT
DO
IF button1 = 1 THEN
PAUSE 100
DO
SEROUT TX, LcdBaud, [noparse][[/noparse]lcdblon, LcdOn1, LcdCls]
'-------------lightmeter---------------------
HIGH 2
PAUSE 2
RCTIME 2, 1, time
IF time > 20000 THEN
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),(lcdline2),"B =0%"," t =", DEC time]
FREQOUT 14, 105, 1661
ELSEIF time < 20000 AND time >= 18750 THEN
FOR idx2 = 0 TO 4
LOOKUP idx2, [noparse][[/noparse]0, 1, 2, 1, 0], s
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,(lcdline2),"B =6%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 100, 1760
NEXT
ELSEIF time < 18750 AND time >= 17500 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,(lcdline2),"B =13%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 95, 1865
NEXT
ELSEIF time < 17500 AND time >= 16250 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,(lcdline2),"B =19%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 90, 1976
NEXT
ELSEIF time < 16250 AND time >= 15000 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,(lcdline2),"B =25%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 85, 2093
NEXT
ELSEIF time < 15000 AND time >= 13750 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,(lcdline2),"B =31%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 80, 1217
NEXT
ELSEIF time < 13750 AND time >= 12500 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,(lcdline2),"B =38%"," t =", DEC time]
PAUSE 75
NEXT
ELSEIF time < 12500 AND time >= 11250 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,(lcdline2),"B =44%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 70, 2489
NEXT
ELSEIF time < 11250 AND time >= 10000 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,(lcdline2),"B =50%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 65, 2637
NEXT
ELSEIF time < 10000 AND time >= 8750 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,(lcdline2),"B =56%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 60, 2793
NEXT
ELSEIF time < 8750 AND time >= 7500 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =63%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 55, 2960
NEXT
ELSEIF time < 7500 AND time >= 6250 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =68%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 50, 3136
NEXT
ELSEIF time < 6250 AND time >= 5000 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =75%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 45, 3322
NEXT
ELSEIF time < 5000 AND time >= 3750 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =81%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 40, 3520
NEXT
ELSEIF time < 3750 AND time >= 2500 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =88%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 35, 3729
NEXT
ELSEIF time < 2500 AND time >= 1250 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =94%"," t =", DEC time]
PAUSE 75
FREQOUT 14, 30, 3951
NEXT
ELSEIF time < 1250 AND time >= 0 THEN
FOR idx2 = 0 TO 4
SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =100%"," t =", DEC time]
PAUSE 75
NEXT
ENDIF
PAUSE 100
IF button1 = 1 THEN
FOR idx3 = 0 TO 2 STEP 1
NEXT
SEROUT TX, LcdBaud, [noparse][[/noparse]LCDCLS, (lcdline1),2,1,0,1,2,"SEE YA",2,1,0,1,2 ]
ENDIF
IF button1 = 1 AND idx3 = 3 THEN
'----------------outro-------------------
FREQOUT 14, 75, 4186
FREQOUT 14, 25, 2637
FREQOUT 14, 25, 2093
FREQOUT 14, 25, 1993
FREQOUT 14, 25, 2193
FREQOUT 14, 1000, 2093, 2098
EXIT
ENDIF
LOOP
ENDIF
PAUSE 500
SEROUT TX, LcdBaud, [noparse][[/noparse]Lcdoff, lcdbloff ]
LOOP
PS: On a side note, with this part of the code:
IF button1 = 1 THEN
NEXT
ENDIF
anyone know why idx3 somehow goes to 3 and why "IF button1 = 1 AND idx3 = 3 THEN" is the only way I can get the button to turn off the lightmeter? Seems like I'm missing something here.
Since many of the SEROUTs do practically the same thing look for ways to store similar things in DATA and CONs then you could have maybe one or two SEROUT that you call and pass in the data.
Tony
Post Edited (Tony B.) : 3/2/2010 2:42:18 PM GMT
'msg2··········· DATA· "· Mechatronics· "
'msg3··········· DATA· "· is AWESOME!!· "
msg2··········· DATA· "· M"
msg3··········· DATA· "· i"
Above uses less EEPROM space. Try adding a bit more to a message and see what happens...
ELSEIF time < 2500 AND time >= 1250 THEN FOR idx2 = 0 TO 4 LOOKUP idx2, [noparse][[/noparse]0, 1, 2, 1, 0], s SEROUT TX, LcdBaud, [noparse][[/noparse](lcdline1),s,s,s,s,s,s,s,s,s,s,s,s,s,s,s,(lcdline2),"B =94%"," t =", DEC time] PAUSE 75 FREQOUT 14, 30, 3951 NEXTThis is repeated many times with only small changes. In particular, the lower and upper time range, percent shown, and FREQOUT value are the only things changed. These could be stored in a table using only 5 bytes per entry since you need only one time bound (lower or upper) if you search the table from the beginning each time. Similarly, you could store the power-on song and the "outro" song as a sequence of two byte FREQOUT values using a zero or -1 as a "stop" entry and have a little loop to play them like this:
To play the power on song, you'd do:
Then you'd do:
temp is just a word variable as is position. They can be used for other temporary purposes elsewhere in the program.
Encoding your data in tables in EEPROM is often a great way to save space in a program with a lot of repetitive stuff.
kicknitinkc, looks like you are doing some great work and really getting the hang of things.
For examples of tables, and to compact your FREQOUT songs, see Chapter 8 of What's a Microcontroller.· For examples of reusing a Temp variable, and for squeezing a lot of sensor data into a small space, take a look at·Advanced Robotics with the SumoBot.
-Steph
'0 1 2 3 4 5 frequencies DATA Word 1993, Word 2093, Word 2193, Word 2349, Word 2637, Word 2793, '6 7 8 9 10 11 Word 3136, Word 3520, Word 3951, Word 4086 ,Word 4186, Word 4286 IntroSequence DATA 1, 4, 6, 3, 5, 7, 4, 6, 8, 5, 10, 9, 10, 11, 10, 9, 10, 11 OutroSequence DATA 1, 10, 5, 8, 6, 4, 7, 5, 3, 6, 4, 1, 0, 1, 1, 2, 1, 0, 1 '0 '1 durations DATA 25, 75 DurationSequence DATA 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 freq VAR Word duration VAR Word index VAR Byte INtro VAR Byte outro VAR Byte durationseq VAR Byte '--------------power on song----------- PAUSE 250 FOR index = 0 TO 18 READ IntroSequence + (index * 2), intro READ frequencies + (intro), Word freq READ durationsequence + (index * 2), durationseq READ durations + (durationseq), Word duration 'play last note with mixed frequency IF index = 18 THEN FREQOUT 14, 1000, 4186, 4191 ELSEIF index => 0 AND index <= 17 THEN FREQOUT 14, duration, freq ENDIF NEXTThanks for the references and encouragement Steph, I've read most of "What's a Microcontroller?" and I had a rough time with that chapter haha. I'm now checking out the "AppliedSumo" book for that temporary variable thing.
Thanks for your help.
Post Edited (kicknitinkc) : 3/3/2010 7:01:30 AM GMT
I added my final code if anyone is curious
The setup is:
photoresistor w/ 0.1mF cap. pin 2
pushbutton pin 3
speaker pin 14
serial lcd pin 15
Post Edited (kicknitinkc) : 3/3/2010 7:12:48 AM GMT
DATA word 1993, word 100 ' freq 1993 for duration 100 (default repeat count = 1)
DATA word 20, word 1993, word 100 ' freq 1993 for duration 100 repeated 20 times
'{$STAMP BS2} ' {$PBASIC 2.5} index VAR Byte frequency DATA Word 20, Word 1993, Word 100 freq VAR byte FOR index 0 TO 20 READ frequency, Word freq FREQOUT 14, ???, ??? nextI guess I'm confused about how I would call out that data using FREQOUT.
