proto board tv wiring
I have the RCA to Breadboard Adapter to add TV but where are the instructions?
The idea is to add the accessory pack for mouse, keyboard, vga and then add
the RCA adapter for TV composite video.
I checked the prop proto board manual, Cookbook, and Jeff Ledger's
Intro to the Propeller Protoboard, PE Lab Manual, and Propeller Manual
but didn't see it.
Item code 28050 RCA to Breadboard Adapter Price $4.99
www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/catpageindex/2/Level/a/ProductID/514/Default.aspx?SortField=ProductName%2cProductName
humanoido
but didn't see it.
humanoido
ucontroller.com/Propeller%20Protoboard%20Designs%20for%20the%20Beginner.pdf
OBC
New to the Propeller?
and wanted to add video. It turns out that the 3 resistor solution is the one that works best...
and the values for a three pin solution are different values from the 4 pin setup.
there is also a one pin solution and someone is probably building a sixteen pin solution as we
speak[noparse]:)[/noparse]
The base pin is 1K, next up is 470ohm
then on the third pin is a 220ohm. you run each of these to the same place and this becomes your
signal line. take you groud from you connector back to your your Prop ground.
I futzed and futzed and futzed with this[noparse]:)[/noparse]
rich
didn't choose my combinations to keep the current ratio's correct. the exact values
are in Radioshack's big resistor pack.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Jim
showing where to solder the RCA jack and resistors, on the Propeller Proto Board.
If there is a standard location, I want to follow it. If not, I can just follow the
schematic and put the jack anywhere on the board.
humanoido
