R/C Car ESC & BOE
Hello Folks,
After you wonderful people helped me figure out how to control my r/c servos, I started thinking about other r/c controls.
I'd like to be able to control my r/c ESC's using my Board of Education & BASIC Stamp 2.
Is this possible &/or feasible?
Scope
Scope
Check out the Propeller Wiki·and contribute if you can.
Many ESC's have power on the red/black wires of the 3 pin connector that goes to the reciever, you DO NOT want that power to feed into the BOE, you just want the signal line. I hope you haven't tried anythign yet and damaged something [noparse]:([/noparse]
I've allocated time resources for testing procedures this evening. Results are scheduled to be provided here accordingly.
Thanks again.
[noparse]:)[/noparse]
R/C car ESCs have a safety feature that prevents the car from going from full forward to full reverse. Normally, if the car is moving forward and you send it a reverse pulse width, it just brakes to a stop. I tried to get it to reliable go into reverse for a week and gave up. I assume that the motors must be motionless and the control at neutral before reverse can be engaged.
My solution was to replace the ESC with one made for robotic uses. Parallax sells one that may meet your requirements.
Rick Brooks
So if it doesn't work, perhaps you haven't sent it the command it's waiting for yet. As mentioned it might be 750, maybe 0, maybe something else.
"puff"...... Smile, there went another one.
I didn't know Parallax sold them - problem solved. Are you referring to the HB-25 motor controller? If so, I have two of them but I thought these were for something else.
If you are replacing a brushless ESC, to drive a brushless motor (it has three power wires) then the HB-25 would not work.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
No, I have all types of motors around here - brushed & brushless.
I looked up "motor controller" at the Parallax home page and several items popped up - I think I should read through them and try to figure out what looks like a good fit for what I'm trying to do.
Thanks again,
Scope
I was referring to the HB-25. If your application is less than 16.0 volts and 25 amps continuous, then it should work fine. My application exceeded both limits, so I had to go with another solution.
If the original ESC doesn't work out, having a couple alternatives to play with is a definite plus.
Rick Brooks
But how I can obtain brushless motor control via my Board of Education & BASIC Stamp 2 - does Parallax have a brushless motor control also?
And . . . (sorry) . . . my 2 cell lipo's shouldn't drop below 3V per cell - is there something I can do to prevent this from happening? As is, my r/c car ESC's have automatic voltage shutdown, rated at 3V per cell but I wasn't aware of the HB-25 motor control having this same functionality. Isn't it true that lipo's will/could get damaged if their voltage drops below 3V per cell?
Here's some links:
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9744&Product_Name=Hobby_King_Voltage_&_Temperature_Monitor_2-6S_(0-150C)
http://www.rc-flysoft.com/Manuals/LMonMan_01en.pdf
The RC stuff has built in voltage monitoring..... Especially the aircraft components where Lipo's are the standard.
