Watchdog timer type issue.
Hi all,
I have about as simple a program as it gets. I'm looking at a PIR sensor and when it goes high I turn on a motor on a FDC6324 driver for one sec. What's odd, is every now and then it locks up and keeps running. Stranger still, the program seems to keep running and then the thing finally resets if I move in front of the sensor again. I'm thinking it must be some strange hardware issue, but I wanted to get the code up here and see if someone thinks it's something I am doing in software.
I'm using the application circuit outlined in the app note. R1 is 100K, R2 is 10K and C1 is·1000pF. Pin 5 of the FDC is from the Stamp through a 220 Ohm resistor.
Is there a way I can check if the output has been going longer than the second or so and force it low.
Do you want to always be able to trigger the sensor, then the motor runs?
There is no watchdog timer available on the Stamps.
I suspect you have a hardware problem. It may be that electrical noise from the motor is causing the Stamp to reset during the PAUSE when the motor is on. When the program restarts, the I/O pin going to the FDC is put into input mode which is a high impedance and the FDC still sees a high enough voltage so it stays on. One easy solution is to put a LOW 12 statement at the beginning of your program, before the start: to force the I/O pin to the FDC to an off state.
That still doesn't solve the problem of why the program restarts sometimes. You may need a different power arrangement or additional filtering for the motor. It's hard to tell without more information about your whole setup.
Post Edited (Mike Green) : 3/1/2010 6:38:16 PM GMT
Just an aside, I have noticed when using the propeller, that serial debug seems to need to be disabled if you don't have it hooked up to the computer, I have a debug statement in here that isn't hooked to anything when it's on the bench, is there a rule about debug for the Basic Stamp? I haven't run into this before, but I am also not seeing any major hardware issue.
@ Bill190, yes I want to infinitely loop and whenever the PIR "sees" something and outputs a "1" to run the motors for a half second.
Other than some sort of hardware error, there's no way that the program would lock up where the motor would continue to run as you described. I can understand how the PIR sensor could trigger again and the motor restart after a very brief pause, but it wouldn't continue to run.
I'm going to put a protection diode from the FDC6324 output (pin 3) to the V+ of the motor and see if that makes things ok. I agree it must be some hardware issue. I'm wondering if there's some strange back EMF from the motors holding the output FET in some indeterminate state, the diode should stop that. Strange that the problem seems to behave with the three Low 12s in there though.
I'll post what happens.
