Protoboard Wiring best practices
I just got my first Prop Proto USB board.· Very Impressive.· I haven't done board level work in a long time so here is my question·and it's kind of an open ended one.· What are the best practices / standards for developing using the protoboard?· Specifically, are there preferred methods for extending the built in buss lines ( 5V, 3.3V/VDD )?· Considering the number of VSS terminations, I don't think I'll run out of connection points there anytime soon
Leon Heller
Amateur radio callsign: G1HSM
If you plane to use your Prop Proto Board as more of an exercise board instead of dedicated to one project I have seen other members on the forum add header sockets to the I/O around the Propeller so they could use pieces of wires to connect to a breadboard.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Here's a ink that will give you some ideas.
ucontroller.com/Propeller%20Protoboard%20Designs%20for%20the%20Beginner.pdf
OBC
New to the Propeller?
www.tdswieter.com
Works well and allows me to use one protoboard for many circuit prototype designs.
I have a tip for you, if you make longer runs. I got this wire with a hot melt glue coating from http://www.preleg.com/. It really works great to tack down your wire for larger mods. I also use it to position my 32guage wire just right to solder onto the side of a .01" pich chip. We're talking at least twice the pins/inch of the qfp propeller. It is quite handy.
I don't know if it is necessary for short runs on a protoboard, but it might be handy sometimes.
Doug
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
