Parallax Serial Terminal Request
In Parallax Serial Terminal (PST) there is an check box in preferences to "Automatically disable (close port) when application is inactive". I like this option as sometimes I need to leave the serial terminal open while watching data in other applications or I need the serial port to enable/disable as PST loses focus. This is great. However what I would like to request it that the option under this, the "Wait for busy port" option to be able to be checked/unchecked no matter the checked/unchecked of the option above. In other words I would like to have the behavior of the Enable/disable button to always wait X seconds no matter if the application is being used in an always open port or in the enable/disable on focus.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
www.tdswieter.com
