Receiving XBee data okay, but not able to send.
I have 2 XBee's, one on my robot, the other hooked up to my computer. I can send data from the computer to the robot, and it works great. But sending the data from the robot isn't working. I have pin 12 running through a resisters to convert 5V down to 3.3V and going to the XBee's Din pin, and have flow control disabled on the XBee. I also tried disabling the CTS parameter on the XBee on the robot.
I'm wondering if there is a setting I need to change, or if I need to actually wire up the CTS pin to the robot. I would think I shouldn't need to, the XBee manual says a minimum of Vss, Vdd, Din, Dout need to be hooked up.
I have verified the XBee is able to transmit when I have it hooked up to my other computer via the USB Adapter board. both ends send and receive perfectly.
www.perfectaperture.com/robb
TX PIN 12 RX PIN 11 BAUD CON 84 '9600 8N1 SERIN RX,BAUD,perror,WAIT_TIME,timeout,[noparse][[/noparse]temp] 'works great SEROUT TX,BAUD,[noparse][[/noparse]"Read you",CR] 'never gets received on the other end
2) You also need to either disable or support flow control on the PC side. If the PC xBee won't accept data, the robot side can't send it.
3) The CTS signal on the robot side tells the robot whether it can send information or not. It doesn't actually affect whether the robot can send.
Other parameters to look at:
DH should be zero in order to enable 16 bit (MY) addressing.
D6 should be 0 to disable RTS handshaking
D7 should be 0 to disable CTS handshaking
Have you read through Martin Hebel's Appbee documentation?
Tracy Allen
www.emesystems.com
