Limbo time, PWM, DC Motors, and stiction. How slow can you go. — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2010-02-27 19:20 in Propeller 1
As part of my MultiPLC http://forums.parallax.com/showthread.php?p=791643 work I have just been playing with some small DC motors and PWM. Just thought I'd share this short video that shows how slow you can go with a DC motor. By choosing the right frequency for the motor at a certain load and speed you can make it go very slowly and relatively smoothly. I am just using the standard PWM object connected to a pair of transistors in a ULN2803. A general-purpose object for open-loop motor speed would then calculate or lookup the best frequency for a given speed. A closed loop can utilize this method as well. I found with these motors that a range from 5 to 50Hz or so usable with higher frequencies only suitable for higher speeds but without any real advantage. Anyway, I thought some might be interested.
Video (1MB) pbjtech.com/propeller/pwm1.avi
*Peter*
    edited 2010-02-27 17:17
    Interesting, what kind of load curve can you ascertain from such slow speeds I wonder?
    When I first read this, the first thing that came to mind was a variable switch-mode power supply which can be an effective and efficient way of controlling DC motor speed, but I don't think you can go as slow as you have achieved using that method.
    Beau Schwabe
    IC Layout Engineer
  • DufferDuffer Posts: 374
    Wow, That's even slower than Progress Bars when installing Windows programs. You have to put the mouse pointer at the leading edge to see if it's really moving at all! lol.gif
    Duffer
    Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
    On the old teletype machines the character selector had to be driven by high volts (80V+) via a resistor to get the time constant (L / R) short enough. I wonder is the same is true for a short PWM pulse into the inductance of the motor.
    Addit Or key on / off a constant current source
    Style and grace : Nil point
    Post Edited (Toby Seckshund) : 2/27/2010 7:47:57 PM GMT
