Rock Bottom Propeller Kit -- Now Available — Parallax Forums
Brian RileyBrian Riley Posts: 626
edited 2010-03-05 19:30 in Propeller 1
A while back I created a series of minimalist processor kits for some PICAXE and two different Arduino Processors. I call them 'Rock Bottom' Kits .... that is what they are ... the absolute rock bottom least components you need to get your microP up and accepting programs. I figured it was time to do that for the Propeller, The basic RBPK contains
- Parallax Propeller chip P8X32-D40A
- Parallax sticker for the DIP chip with pin assignments
- Microchip 24LC512
- 3M dual wipe DIP sockets for both
- 5 MHZ crystal
- 10K pull up resistor for SDA on EEPROM
- reset switch
- 2 0.1uF bypass caps
- 16 each 1/8 watt carbon film series protection resistors in 1 Kohm and 220 ohm values
- a special bonus, red LED with built in series resistor for easy quick and dirty debugging
I offer an inexpensive RS232 level programming adapter, breadboard, 5v/3.3v power supply etc as an additional options. The basic RBPK is $15 and it can be seen here
www.wulfden.org/TheShoppe/prop/rbpk.shtml
The kit can be breadboarded (save those sockets) or mounted to a larger Radio Shack proto board.
Cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
Post Edited (Brian Riley) : 3/5/2010 7:29:41 PM GMT
800 x 770 - 99K
600 x 800 - 71K
    edited 2010-02-27 13:32
    This is a really nifty collection of products. I like the breadboard approach too, as it makes it easy to start adding things and experimenting.
    www.smarthome.viviti.com/propeller
    edited 2010-02-27 17:08
    @Brian,
    My hat is off to you! Excellent!
    You should have a kit price which includes that RS232 programmer for $19.00 (If I read your website correctly)
    Edit: A thought.. How about adding a 3.3v regulator and a nine volt battery clip?
    It may not be a "recommended" approach, but I'll bet it would work.
    OBC
    New to the Propeller?
    Post Edited (Oldbitcollector) : 2/27/2010 5:26:07 PM GMT
  • Brian RileyBrian Riley Posts: 626
    edited 2010-02-28 18:50
    Oldbitcollector said...
    @Brian,
    ... (If I read your website correctly)
    OBC
    Thanks, both of you for the kind words. But the part I just quoted got me to read the webpage over again a (after a proper night's sleep!) and I see how things could have been more clear. Anyway, I cleaned it up and, I hope, made it more clear.
    My lack of clarity not withstanding, the web site sold 8 kits that first night and yesterday I had a table at the Vermont State ham radio convention at the Hampton Inn near Burlington and sold another 14 RBPKs, 12 of them to brand new Propeller-heads. Fortunately they had expanded free WiFi into the area we were in (last year they wanted to charge us a fortune for WiFi!) so I was able to show off the Forum. I handed out over 30 Parallax catalogs (the last of my 2009 stash and about 18 2010's) !
    Once again the RBPK webpage is ]www.wulfden.org/TheShoppe/prop/rbpk.shtml]
    cheers ... BBR
  • rjo_rjo_ Posts: 1,825
    edited 2010-03-01 06:00
    Brian...
    Hate to say this... but the top link is dead. The bottom works just fine.
    You know those books..."____ for Idiots"? I'm one of those idiots. I couldn't find a picture... like you posted here... showing the prop-plug kit. I know it is there... but when I followed the links, it wasn't where I looked.
    Great concept... nice kits.
    Rich
  • heaterheater Posts: 3,370
    edited 2010-03-01 08:03
    Except a true "rock bottom" Propeller kit does not need an XTAL or an EEPROM to get started programming with.
    That's one of the things that got me instantly hooked on the Prop, it runs with almost nothing. Which is pretty much what I had at that moment.
    The LED and its resistor are essential of course[noparse]:)[/noparse]
    Rock Bottoms Kits are a great idea I must say. The absolute minimalist system is the first thing I look for in every new device I come across.
  • Paul Sr.Paul Sr. Posts: 435
    edited 2010-03-01 16:19
    rjo_ said...
    Brian...
    Rich
    You just need to remove the right bracket ("]") from the end.
    edited 2010-03-01 21:57
    Brian Riley said...
    @Brian,
    OBC
    Once again the RBPK webpage is www.wulfden.org/TheShoppe/prop/rbpk.shtml
    cheers ... BBR
    I fixed it .... thanks ... BBR
    edited 2010-03-01 22:04
    heater said...
    I actually considered the crystal and EEPROM aspect ... buuuuutttttt ... they involve subtleties that might get confusing to a rank beginner ... so I left them in ... sort of a case where "a little more" winds up being "less!" Anyhow, that's my story, and I am stickin to it!
    cheers ... BBR
    edited 2010-03-01 23:54
    Hello Brian,
    Thank you from Parallax for joining the Propeller crowd and making a kit to support this processor. Now that you're kitting RBPKs, we won't bother! You've been around for a while with our products, especially with the SX product.
    Let us know if there's anything we can do to help you along with the RBPK.
    Sincerely,
    edited 2010-03-02 00:37
    Ken Gracey (Parallax) said...
    Hello Brian,
    Sincerely,
    Thanks, I appreciate it. Its little I can do to pay back all the Parallax community has done for me through the years and make a little money to fund my 'next great idea' should there be one left in the nether reaches of my skull!
    cheers ... BBR
    Upon further discussion and consideration, I added to the kit, 16 each of carbon film resistors in 1 Kohm and 220 ohm values. The list above has been edited to reflect the addition.
    cheers ... BBR
