Powering a bS2 with 120 vac
O.K. at the risk of sounding totally stupid. I'm looking for a way to power a BS2 using 120 VAC without a transformer. Isn't there a way to run the line voltage through a full wave bridge and then and then feeding it through a regulator to power the stamp without involving a transformer? What am I missing? Thanks for replies in advance.
They are a little more expensive...
http://computer.howstuffworks.com/power-supply1.htm
The switching power supplies used today are much smaller and lighter. They convert the 60-Hertz (Hz, or cycles per second) current to a much higher frequency, meaning more cycles per second. This conversion enables a small, lightweight transformer in the power supply to do the actual voltage step-down from 110 volts (or 220 in certain countries) to the voltage needed by the particular computer component. The higher-frequency AC current provided by a switcher supply is also easier to rectify and filter compared to the original 60-Hz AC line voltage, reducing the variances in voltage for the sensitive electronic components in the computer.
A switcher power supply draws only the power it needs from the AC line.
dU = 120V - 5V = 115V
I = constant -·select 100mA peak 1A
you must neutralize 11,5 W of heating, for 1A 115W! You need·massive heatshink, bigger than transformer.
115W peak power consumption in stamp·device - new record.
C-Bob
Every problem·have at least one·nice, simply and·wrong solution.
http://en.wikipedia.org/wiki/Voltage_divider
www.aikenamps.com/VoltageDividerRule.htm
its how my Kill-O-Watt Meter I have works . but its only good for isolated devices .
I would drop the voltage to 16V AC the rectify to DC then across the DC line put a TVS (transient voltage suppressor) rated at 20V to for the LM chips Safety and then drop it again with a LM REG to 5V to run said Stamp .
Note your load must not vary much for this to work well ..
I have used it for a many projects .
KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
Post Edited (Peter KG6LSE) : 2/27/2010 12:53:56 AM GMT
