First read the documentation for the PIR and PING sensors and look at the Wikipedia articles on these types of sensors (passive infrared and ultrasonic), then come back with specific questions.
The way you phrased your question suggests that this is an educational question, something for class. In that case, you need to do your own research and not ask others to answer your problem for you. If this isn't the case, you still need to do enough research to understand the question enough to pose more specific questions and also to show what you do understand so others can answer in terms that you know already.
It is not educational, it is for my own research. I have read those documentation but i need some technical data.
I am designing a SEAT DETECTION SYSTEM FOR OFF-HIGHWAYS TRUCK to detect operator in seat. I need the BEAM PLOT for this particular sensor and more technical information. I also was looking for factors which can effect of detection to check if my designed system works.
- Stephen
