Propeller and USB
I'm wanting to hook up my propeller to a usb hub to allow it to communicate with various other devices which I would have to write some type of driver for the propeller for I expect.· My question is more about the hardware.· I really don't want to use the programming USB port for this.· I'm not sure if it would work either.· So what do I need to use?· Will the Memory Stick Datalogger serve as a USB to normal serial converter for this type of connectivity?·· So for example, what would I need to hook up a USB keyboard and mouse instead of the PS2 ports available on the board?
If you are wanting to connect other USB devices, you might want to look at the datalogger. It functions as a USB host. I have used it to connect a HID, specifically a joystick, to a BS2. With it's memory and speed, the Propeller should be able to read it easily.
My notes are at:
http://forums.parallax.com/showthread.php?p=870754
