PropBASIC program that modifies EEPROM to change a hub variables default value
Bean
Here is a program that writes to the EEPROM to change a hub variables default value.
This is useful to make parameter changes that are remembered even when the propeller is turned off.
Bean.
Note that there is a bug in version 00.00.85 with the I2C commands so you need version 00.00.86
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Bean.
pbas
1K
