help with project
i am designing a program that will close the garage door after 10 minutes. I have that part of the program done but would like to modify it so that if a switch is close that is disable the program but will not override the alarm clock part of the program using ds1302 and can show parts of the program on the lcd screen. Also if is possiable to always display the temperature not require
thank you for any help
Ryan
Post Edited (ryan4385) : 2/25/2010 4:45:42 AM GMT
Ryan
A few questions; what is or is not working in the program that you have attached with the RTC program you want to merge.·Can you upload the entire program you want to use? The reason I ask, is that it's easier to offer suggestions when we have all the pieces.
Respectfully,
Joshua Donelson
www.parallax.com
IF switch = open
DoThis
endif
rest of your code
- Stephen
' ========================================================================= ' ' File...... DS1302_Counter_Demo.bs2 ' Purpose... Demonstrate The DS1302 Clock & RAM Functions ' Author.... Chris Savage -- Parallax, Inc. ' E-mail.... [url=mailto:csavage@parallax.com]csavage@parallax.com[/url] ' Started... ' Updated... 10-09-2005 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' ' Pin Assignments ' 0 DS1302 DataIO ' 1 DS1302 Clock ' 2 DS1302 Chip Select ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- DataIO PIN 4 ' DS1302.6 Clock PIN 3 ' DS1302.7 CS1302 PIN 5 ' DS1302.5 ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- WrSecs CON $80 ' Write Seconds RdSecs CON $81 ' Read Seconds WrMins CON $82 ' Write Minutes RdMins CON $83 ' Read Minutes WrHrs CON $84 ' Write Hours RdHrs CON $85 ' Read Hours CWPr CON $8E ' Write Protect Register WPr1 CON $80 ' Set Write Protect WPr0 CON $00 ' Clear Write Protect WrBurst CON $BE ' Write Burst Of Data RdBurst CON $BF ' Read Burst Of Data WrRam CON $C0 ' Write RAM Data RdRam CON $C1 ' Read RAM Data ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- index VAR Byte ' Loop Counter reg VAR Byte ' Read/Write Address ioByte VAR Byte ' Data To/From DS1302 secs VAR Byte ' Seconds secs01 VAR secs.LOWNIB secs10 VAR secs.HIGHNIB mins VAR Byte ' Minutes mins01 VAR mins.LOWNIB mins10 VAR mins.HIGHNIB hrs VAR Byte ' Hours hrs01 VAR hrs.LOWNIB hrs10 VAR hrs.HIGHNIB date VAR Byte month VAR Byte day VAR Nib ' Day year VAR Byte ' Year work VAR Byte ' Work Data ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Init: reg = CWPr ' Initialize DS1302 ioByte = WPr0 ' Clear Write Protect GOSUB RTC_Out ' Send Command ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Start: mins = $00 secs = $00 GOSUB Set_Time DO GOSUB Get_Time DEBUG HOME, HEX2 mins, ":", HEX2 secs IF mins = $03 AND secs = $15 THEN EXIT LOOP DEBUG CR, CR, "3:15 Elapsed" STOP ' [color=red]<<<<<<<<<<[/color] ' [color=red]The STOP line is not need when you put own code bellow [/color] RETURN ' [b][color=red]one note you may or may not this line this depends on how you write you code [/color][/b] [b] [/b] [color=red]' remove the stop and put what you want it to do[/color] [color=#ff0000] ' and do not for get the RETURN line at the bottom[/color] ' [color=red]of this routine[/color] ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- RTC_Out: HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg, ioByte] LOW CS1302 ' Deselect DS1302 RETURN RTC_In: HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg] SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]ioByte] LOW CS1302 ' Deselect DS1302 RETURN Set_Time: ' DS1302 Burst Write HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]WrBurst] SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]secs, mins, hrs, date, month, day, year, 0] LOW CS1302 ' Deselect DS1302 RETURN Get_Time: ' DS1302 Burst Read HIGH CS1302 ' Select DS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst] SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year] LOW CS1302 ' Deselect DS1302 RETURNI hope this helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/28/2010 4:07:18 AM GMT
