Using a screen with the boe-board — Parallax Forums
Drew n MattDrew n Matt Posts: 5
edited 2010-02-24 19:22 in BASIC Stamp
Is it possible to use a small lcd screen with boe-board. Not nescessarily a lcd screen but like a small screen, we are making an alarm clock so we were wondering if it would be possible to make a small screen to display the numbers on our alarm clock.
    edited 2010-02-24 17:57
    That can be done but it depends on the screen you choose. Get the specs and link the datasheet if you have a specific device in mind. Don't buy the device before doing your research!
    - Stephen
    edited 2010-02-24 18:05
    Look at some of the LCD panels that Parallax sells. They're typical of what's on the market.
    I have Parallax's LCD Terminal Appmod currently on my BOE-board. Actually works out great because it doesn't block the breadboard. Page 2 of the LCD Terminal AppMod Documentation PDF shows a picture of the LCD appmod on a BOE.
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    Special Olympics Polar Bear Plunge, Mar 20, 2010
