Which sensors can I use?
Hello,
My name is Glenn Groeneveld and i'm a student Industrial Design in Holland.
For a project i want to automaticly·keep track on how many balls went into the (soccer)goal. (I'm doing an intern at a company which makes sport products).
I found·the X-band motion detector on this website, but al the specs are a bit overwhelming to me.
I just want to know if this device (or which sensor) can "see" the ball passing en sends out a signal to a (some kind of) scoreboard.
I was also thinking about an active infrared signal with a reciever, so that if the ball passes he crosses the beam and that is registered.
Can you help me with my·problem?
Thanks in advance,
Glenn·
Thanks in advance,
Glenn·
- Stephen
As it's being a training object, there is no goalie involved. So that won't be a problem.
So you would suggest an optical sensor. I will go and have a look on Parralax and hopefully I can find it here. I already tried to find on google but it send me to (home)security websites, while i just want the sensors and a scoreboard
I have never heard of a line scan sensor, can you elaborate? I did come across a system that Fifa and Adidas developped with a sensor within the ball and a magnetic strip under the goalline. Is that what you mean?
Thank you again,
Glenn
www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/Level/a/ProductID/566/Default.aspx?SortField=ProductName%2cProductName
A official goal is 7.32 meter wide and i don't know if the line sensor can scan that far.
I couldn't find an optical line sensor by "object detecting".·What website·can·i find them?
I did see a ultrasonic sensor: http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/Level/a/ProductID/92/Default.aspx?SortField=ProductName%2cProductName
Do you guys think this is suitable?
I included a sketch of the idea. In all corners ther are movable parts, so the trainer can decide where the player has to shoot.
I think that the should be a sensor in each corner, positioned behind the pole.
Maybe this clarifies the idea.
Glenn
This is something of a brute force approach but it has the advantage of low cost and simplicity.
