Inter Propeller communication
Hi all,
I've been searching a lot in the forum and on the web but couldn't find what I needed. So i do apologise if the question has been answered already, but I have been unable to find it.
Ok, my problem is this: I need to make 2 Prop chips talk to each other, the idea is that one chip collects readings from a variety of sensors and is supposed to send it to another prop for datalogging and interfacing with the internet etc...
So the prop looking after the sensors sends out a data sequence, starting with a certain pattern, then followed by the actual sensor readings, finally the sequnce is finished. I mucked around with the BS2 functions and the SERIN SEROUT commands, but I ended up having trouble with the handshaking/synchronisation. If the sensor prop pumps out the data with a little (100ms) pause between the different data bits, the other side picks it up, but the moment I introduce a handshaking mechanism (where the receiveing prop uses SEROUT to signal the receipt of the data and indicating it is ready for new data), it fails. It is maybe that I don't fully understand the SERIN/OUT routines and whether or not they wait for data.
I've tried using different pins for the data and acknowledge, and then also two different instances of the BS2 function object, to no avail. If it is unacknowledged, it works, but with handshaking, it doesn't
So my general question is this: How do I implement a simple protocol between two props where data can be requested, sent and acknowledged? I couldn't find anything in the OBEX. It really doesn't have to be fast, the data needs to be sent across every minute or so, so heaps of time.
I looked at this video here, but this might be a total overkill
http://www.parallax.com/Portals/0/Downloads/mm/video/Webinar/2009-03-17-9a-Webinar-[18].wmv
any help is much appreciated
Frank
Frank
If you want a robust protocol, you can add checksums and more timeouts.
I recently posted an XModem receive routine here: http://forums.parallax.com/showthread.php?p=819353
I don't have the corresponding transmit routine, but it would be simpler than the receive routine.
Beau has a version that communicates >8Mbps but IIRC it uses 2 cogs.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
Leon Heller
Amateur radio callsign: G1HSM
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
So far I've only tried the BS2 functions as I wanted to keep it as simple as possible. But somehow it doesn't work. Mike, yes, I have set the 2 chips up as master/slave, and the general idea I had was to do it like you suggested, but here I'm running into trouble..
Here's what I have (the initial bits of it, the principle)
On the master side, I do this:
Slave does it like this:
You can see that the master to slave communication uses pin 2, the confirm uses pin 3, both also use different BS2 objects. I thought that might help, but it didn't...
The slave never receives anything
There's more code there, but the general sequence starts like this. If I do this a bit different (without the acknowlegments), it seems to work, but then I get the master firing data at the slave w/o any feedback which is bound to cause trouble or lockups.
And to answer the other questions, no, I haven't tried FullDuplexSerial or fast inter-prop communication yet, I was hoping to get away with BS2 functions. But hey, I will try those as well. With the fast IP comm, I read that the chips need to be runing off the same clock, is that right? My 2 Props are sitting on different boards, each with their own crystal...
And yes, Mike, I will also look at the code you posted (the XModem stuff)...
Cheers
Frank
I tried to put a small edit on my post of Feb 18 to bring it near the top of the present list so I could reference it for you in this post, but that did not seem to work. I don't know how to link to previous posts.
Anyhow, if you take a peek at my post of Feb 18 titled "5Mbit/sec ASCII streaming from/to Hub RAM" , those pieces of code should do, or at least be very easily adapted to what you want. They can run on different boards, hence slightly different crystal frequencies.
Enjoy.
Cheers,
Peter (pjv)
Frank
Thanks for the advice, I had often wondered how that was done.... i'll try that now, so here is that link.
http://forums.parallax.com/showthread.php?p=882980
Cheers,
Peter (pjv)
http://forums.parallax.com/showthread.php?p=820293
In this thread is my blackbox. If you look at the block diagram, you will see that 3 props are communicating to a central prop.
This central prop is acting as a data hub that passes data back and forth. This central prop also programs all other props.
Check it out, using the full duplex serial object is very easy.
Just don't forget to put 10k pull down resistors on both serial lines. (speeds above 115.2Kbps won't work)
(speeds above 300Kbps won't work for me, my prop to prop wires are 6in long)
Post Edited (Clock Loop) : 2/28/2010 9:52:43 PM GMT
bingo! This works well for me, thank so much! I downloaded the code and schematics, and yes, it seems very simple to run the FullDuplex Serial.
There is one thing however I don't understand fully yet, maybe someone can help me with this little issue.
The Master Prop sends a "transmission start" byte (255), to which the slave responds with a confirmation byte (254). So the code in the master looks like this:
Slave:
So the slave confirms after receiveing the start byte and then waits for reception of 32 data bytes. So far so good, but when I look at the data bytes that are stored in the array I find that the start_trans value (255) is stored in there a few times, and bytes are missing at the bottom of the array.
This means that the master keeps sending start_trans in the repeat loop. This can only mean that the master does NOT wait at this line:
If SerialComm[noparse][[/noparse]0].rxtime(50) == confirm_dat
but that it races through and keeps retransmitting start_trans, which the slave receives in the data array.
So I guess my question is why is the rxtime(50) not sitting there waiting for the confirm byte? My understanding is that this is the whole idea of it?
I can work around it in the slave by ignoring multiple 255 (start_trans) values, but it's not nice to do it like that, and there should be a proper solution to this
anyway, thanks again to everyone here for your brilliant support so far!!
Cheers
Frank
You don't use a loop to push the data with the transmit like you are doing with the receive.
Your tx loop should look like this. I added bold items. You were close.
Post Edited (Clock Loop) : 3/2/2010 4:24:12 AM GMT
If you read the comment on the last line, it says that there are 31 bytes following, so the full code looks like this:
etc... I think you get what I mean. The code I psoted was abbreviated. Sorry, I didn't make myself clear enough, it does push out 32 bytes, which are also received
My point is that the slave receives the start_trans (which has value 255) many times before it receives any of the data bytes.
So in the receive array you see this
This means that the master does not got into the IF statement and keeps sending start_trans. So in essence I believe that the rxtime is NOT waiting for the confirm from the slave, and this is the part that is not clear to me...
there seems to be some sort of race condition.
hope I make more sense now
Frank
well, that might be it... I do want the timeout behaviour to avoid cog lockups. I thought 50ms would be really long since the slave is doing nothing else but wait for the start and then immediately send the confirm. Wouldn't have thought it times out (clockLoop''s code only uses 5ms, and it seems to work fine...), So you might be right, I will test it with say 500ms..
Ta
