Super high torque servos? — Parallax Forums
Miles. kMiles. k Posts: 34
edited 2010-03-02 00:17 in General Discussion
The idea came to me to make a robot out of a ATV. For throttle i could just use a normal servo but to steer i think i need some more power. like a GIANT servo
Any idea's?
Miles
    edited 2010-02-24 03:58
    A large stepper with a potentiometer for positioning. Use a 10 turn pot and have the stepper make 8-10 turns to move the steering over it's range of motion. If you need more torque you could put a 1 turn pot on the steering handle.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-02-24 04:07
    Maybe the K2X-G05?
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
  • kf4ixmkf4ixm Posts: 529
    edited 2010-02-24 04:47
    here's one that can lift 100lb, that should be enough for steering i would think...
    http://www.pololu.com/catalog/product/1390
    0J1904.200.jpg?1256953500
    edited 2010-02-24 05:03
    kf4ixm said...
    That is an impressive servo, but it is only 8 ft-lbs of torque, I think you would need something more rugged for an ATV.
    The linear actuator, if mounted 2" from the axis of rotation, would have 100 ft-lbs of torque and would be essentially immune to shocks.
    Rich H
    edited 2010-02-28 13:55
    There are limits to what a pwm servo is intended to do -- stepper motors can go much, much higher in torque and are used on CNC lathes and milling machines for such purposes, so are even set up as linear actuators.
    Ain't gadetry a wonderful thing?
    aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
  • Agent420Agent420 Posts: 439
    edited 2010-03-01 14:20
    Can't remember where I first saw this, but I note several people have sucessfully converted automotive windshield wiper motors into powerful servos...
    http://www.fieroaddiction.com/servo.html
  • logan996logan996 Posts: 281
    edited 2010-03-01 22:14
    well if your not going to be too right to the point sensitive, couldnt you just buy some heavy duty motor and connect it to the HB- 25's you used in your last project? (which rocked [noparse]:D[/noparse] )
    "When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
    ·Thomas Jefferson
    https://www.servocity.com/html/spg785a-4_5_servo_gearbox.html
