Sharp 8A Solid State Relay Prallax Part # 400-00053 — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2010-02-27 15:03 in General Discussion
Can some one who has use this in the past
Can any one tell what the values that would be used in the· Standard Circuit· the one ·in the data sheet
http://www.parallax.com/Store/Components/Other/tabid/157/CategoryID/32/List/0/SortField/0/Level/a/ProductID/657/Default.aspx
··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 2/26/2010 10:19:30 PM GMT
    edited 2010-02-23 23:58
    Sam,
    What do you mean? Which circuit?
    Parallax Engineering
    edited 2010-02-24 01:24
    The one on page 9 of the Data sheet
    Sam
    edited 2010-02-24 03:53
    @Sam, DigiKey lists 34 items for Sharp 8A solid state relays so you need to be a bit more specific to get an answer.
    PS - Have you received the two boards I sent back to you? They should have arrived a while back.
    edited 2010-02-24 11:44
    sam_sam_sam said...
    Can any one tell what the values that would be used in the Standard Circuit the one in the data sheet
    Yes, I can help in like manner. The Standard Circuit always uses standard values as per the datasheet. If that doesn't work just try the standard thing.
    *Peter*
    edited 2010-02-25 23:43
    The one that Parallax sell
    In the Data sheet dose not give any values on the circuit I do not know ·what to use· Standard Circuit·
    Sam
    Post Edited (sam_sam_sam) : 2/26/2010 10:13:04 PM GMT
    edited 2010-02-26 00:38
    Sam,
    Isn't it a courtesy to at least give a link to the product or be a bit more descriptive? I mean, you have taken the time to ask the question and others take the time to answer or at least read it.
    Do you want each of us to hunt and guess as well?
    *Peter*
  • TubularTubular Posts: 4,745
    edited 2010-02-26 03:10
    Sam,
    Forget the standard circuit, its for Micros that can't source 20mA. Its just an IR LED inside the module (pins 3 and 4)
    If you're using a prop, connect the prop output pin to one side of a 100 ohm resistor (for 20mA through the LED, whose forward voltage is about 1.3v), and other side of the resistor to pin 3 of the sharp module. Connect pin 4 to ground / Vss.
    Agree with others though, more info and/or links up front would get you a much quicker response!
    cheers
    tubular
    edited 2010-02-26 22:14
    Here is the link to what I am talking
    http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/400-00053Datasheet.pdf
    Sam
    edited 2010-02-27 02:19
    FYI what Tubular says applies to most (but not all) SSR's regardless of their output voltage and current ratings. they are IR leds on the input and a series resistor of 100 ohms for 3.3V or 180 ohms for 5V operation is all that is required as long as the micro or other circuit can provide 20mA. You also do not need a snubber circuit on the output for resistive loads with 60Hz.
    I have a 240V 50A three phase SSR from Crydom that is controlled directly from a prop pin through a 100 ohm resistor.
    edited 2010-02-27 14:49
    kwinn
    Thank You for your reply
    I have used Optic sensor before but not this type of SSR
    So when it show part symbol with·NO value then I have·NO··idea.gif·how to use it
    Is a snubber circuit used when you are using a Motor with a SSR
    I want to thank every one who reply to this post
    Sam
    A snubber is used with a motor and other inductive loads to keep the SSR from being turned on by fast voltage spikes.
