Hysteresis and better programming skills...
Hi all,
I'm in over my head, as usual. I am using a reading from the Ping sensor and comparing that to the last couple of readings from the ping sensor to determine if a person is moving toward the sensor, away from the sensor, changing direction or standing still. I attached the code I have written and cobbled together from others. What my boggle is, is to add some hysteresis to the conditionals in my subroutine Track_position. Right now it's a touch too precise, a person can stand still and wobble a couple of inches just because.· I'd like to add +/- 3 inches to each value and then compare the ranges, see if there is any overlap with the conditional statements in Track_position. I am also thinking my brute force method of comparison could use some refinement. I did a search of the forum for Hysteresis and really didn't find much, except for taking four measurements and averaging them to get a more consistent reading. Any body have a good suggestion for me?
Thanks in advance.
Dave
Thanks in advance.
Dave
bs2
8K
