grayfox386 said... thank you for your help how did you install the driver for serial comm with the prop
www.fnarfbargle.com/bst.html
*Peter*
You don't. It's there by default.
You should have /dev/ttyUSB* when you plug your prop-plug in.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
